A practical way to vaporize fuel for high MPG?
  • Thread starter Thread starter NTL2009
    Engine efficiency
The discussion revolves around the feasibility of achieving high fuel efficiency, specifically 100 mpg, through the vaporization of fuel in a modified 1970 Ford Galaxy with a 427 cubic inch V8 engine. The video referenced suggests that fully vaporized fuel burns cleaner and can operate at a leaner air-fuel ratio, potentially improving mileage, but at the cost of performance due to reduced power output. A proposed solution involves using a pre-combustion chamber to facilitate vaporization while addressing safety concerns and efficiency issues. However, skepticism remains regarding the practicality of such modifications, as achieving high mpg without sacrificing acceleration and power appears challenging. Overall, the conversation highlights the complexities and limitations of fuel vaporization technology in internal combustion engines.
NTL2009
TL;DR Summary
For an automobile ICE, could gasoline be vaporized with a hot plate in a small chamber just before the intake valve to improve mpg at cruising speeds?
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved.
He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been realized. The car appears to vaporize the fuel (versus atomizing in a conventional carburetor or fuel injector). He claims a fully vaporized fuel is homogeneous, which burns faster and cleaner with no pockets of lean/rich, and can theoretically run lean, 40:1 ( versus a conventional ~ 22:1 limit ?). He doesn't mention, but I assume there is much lower throttle pumping loss for better mpg.
While he acknowledges it could be done, he says one drawback is very poor performance. I think because vaporized fuel takes up a large volume, so you can only get a relatively small amount of fuel in a cylinder, so limited power. And I think that is why a large V8 was used. That also makes sense from a Brake-Specific Fuel Consumption (BSFC) viewpoint - that big V8 running near open throttle and near full load (at reduced horsepower) would put the engine at an efficient part of the curve. Of course, you can get high mpg by trading acceleration and using a small conventional engine, but you wouldn't get the claimed advantages of fuel vaporization.
OK, so acceleration would be unacceptable. He goes on to say this could be addressed by using fuel injection to accelerate and start the engine, but he seems to poo-poo this as being too complex, and fuel vapors are unsafe. But I think he overstates this. Could there be a pre-combustion chamber on each cylinder, maybe the same volume of the cylinder, or somewhat larger, to hold a supply of vaporized fuel? I could envision a hot plate in that chamber (before the intake valve), and a fuel injector spraying a fine mist onto the hot plate to vaporize that fuel. It would supply just enough fuel for cruising power, the rest of the fuel for acceleration would be supplied by a separate injector that would not cool the plate. The fuel would have time to vaporize as it would be a continuous process. For a pre-combustion chamber the same size as the cylinder, assume 1800 RPM at cruise, at 2 revs per combustion, so 1800/60 = 30 revs/second, so ~ 1/15th of a second (67 ms) to vaporize the fuel. And at 100 mpg and 60 mph ( 1 mile-per-minute), that's 1/100th of a gallon per minute (let's switch to metric at this point!) or ~ 38 ml, divide by 4 cylinders, round to 10 ml, divide by 60 for 0.167 ml/second. I assume that would be do-able, but don't really know. I don't see where this would be a big safety issue, or overly complex.
A pre-combustion chamber would also address the issue he raises that not all components of the fuel vaporize at the same temperature. He claims these components would build up, and have to be drained collected - which would be impractical. But with the pre-combustion chamber, anything not fully vaporized would just be drawn into the engine in atomized form. I don't see a problem here. He seems to be envisioning a large chamber of vaporized fuel supplying all cylinders.
But, it seems we would still need a large displacement engine to get enough horsepower even for cruising speeds due to the volume of the vaporized fuel. That would be a major disadvantage. As I understand, 0.5 L per cylinder is a sort of practical limit for passenger cars engines, and moving to a V8 would be impractical in cost and size for most cars today. Would a supercharger be able to compensate for this, forcing more air/fuel into the cylinder, so maybe a 4 cylinder or V6 could work? Pollution control is another whole story.
Also, for reference, vaporization was used in some early stationary engines (“surface plate carburetor), so it's far from a new idea. But I also wonder, wouldn't running from propane or methane provide similar benefits as attributed to vaporizing gasoline? It's vapor already, right? And flex -fuel engines exist, but I never heard that they run higher efficiency on vapor?
This is really just a mental exercise / thought experiment. But that video made me very curious. Thoughts?
Lnewqban said:
One problem has been keeping the fuel from reaching the boiling point in hot conditions.
Please, see:
https://www.onallcylinders.com/2015...erstanding-vapor-lock-and-how-you-can-fix-it/
But the vaporization would occur right at the cylinder intake, so really no different from avoiding vapor lock in fuel injected engines today. You keep the fuel liquid up to the injector that would inject fuel onto the hot-plate.
Boomer here.. I've seen countless claims of incredible fuel mileage claims over the years. Most are hyping and selling some sort of gizmo technology that does these amazing things. Classic pitches are that the oil companies bought the patent and have buried or hidden the technology due to greed, etc.. The vaporization claim is a common snake oil pitch. I can assure everybody that 100 mpg with a 427 cubic inch is just not going to happen - maybe if the drive is down hill for miles and miles the the car coasts at 120 mph while the engine idles.
The law of physics apply here.. there's only so energy that can converted into mechanical motion via. a reciprocating four stoke engine and driving several thousand pounds of mass down the road.
Don't fall for the miracle fuel milage gizmo con folks.
However if anybody is interested I can post a solution that could increase your fuel milage by up to 10% - I'll post the solution for free.... Cheap using a common household supplies. please, please ask....
Likes russ_watters
In that case, the solution can't be applied to modern direct injection into the combustion chamber, only to carburetors and injection into intake manifold.
Then, expect a slight increase in the volume and pressure of the heated mix, both of which should be working against the airflow and cylinders filling in natural aspired engines.
Simultaneously, taking thermal energy away from the exhaust gases in the heating device may induce problems with condensation of corrosive vapors in the exhaust system.
There is no much more to squeeze out of this old invention that is the IC engine.
In my personal experience, the surest way of saving fuel has been improving planning, reducing accelerations and speeds, and avoiding unnecessary braking and trips. :smile:
My guess is that the engine employed a gas mixer, like on an LPG fuelled vehicle, but produced the gas by boiling high octane gasoline. It is just possible, that it was economic, but with such poor performance, it would be a hazard on the road. Maybe, isolating half the cylinders was employed to halve the engine capacity, to reduce the fuel required.
"Lean burn" gasoline engines, like diesels, run cool, are low NOx, but they are not pollution free. It could not operate under today's emission control laws.
The art of good story telling, involves releasing a minimum of information, and keeping secrets right up to the end. The inventor kept the secret, he claimed it was worth a million dollars, but then he died following a mysterious gunshot wound.
Likes russ_watters and Lnewqban
digitalghost said:
Boomer here.. I've seen countless claims of incredible fuel mileage claims over the years. Most are hyping and selling some sort of gizmo technology ...
Of course (also a boomer, if that matters?), and if that's all there was to this, I would not have posted it to this forum. The reason I found it interesting is, the youtuber I link says that he does think it was possible, he says the math works. But with caveats (see next post)...
edit to add:
It was a round trip, ~ 100 miles out, 100 miles back on the same route. So that was taken into consideration. Not that there couldn't be other 'cheats' that went undetected, but that's beside the point. Whether the demo was real or not, the author of that video, who seems knowledgeable, feels that it was possible.
Baluncore said:
My guess is that the engine employed a gas mixer, like on an LPG fuelled vehicle, but produced the gas by boiling high octane gasoline. It is just possible, that it was economic, but with such poor performance, it would be a hazard on the road. ...
Yes, this is what the author of that youtube video seems to think as well. That it is possible to do, but with very poor performance. I think all cylinders were needed, just to get enough fuel into the engine to even reach cruising speeds.
I was meaning to do some math - how much vaporized fuel could a 427 cu in engine take in per evolution? Is that enough to power that car at 45 mph (I assume he kept speed pretty low). That's why I think a large V8 was used - you need that much displacement just to process enough fuel/air. I think the key to this boils down (no pun intended) to that lean fuel/air ratio which vaporization allows.
Instead of that math, just thinking in relative terms, if a vapor is ~ 40:1 (mentioned in the video), and a 'normal' engine is running closer to stoichiometric (14.7:1), it is taking in ~ 0.36 less fuel. So the engine would produce ~ 0.36 the power, assuming the same efficiency. In effect, the throttle would be ~ 2.7x more open at cruise than it would be on the 'normal' engine. And, as mentioned above, this would put it closer to the 'sweet spot' on the BSFC map, adding to efficiency.
As stated in my OP, part of this possible 100 mpg comes from, in effect, running a small (say 20 HP) engine at near wide open throttle at near full load. You can get very good mpg, but can't accelerate enough for safe driving, or maintain speed up a grade or into a head wind. Then add in the supposed efficiency of vapor vs atomized fuel, and you just might get 100 mpg. But with vapor, you need that large displacement engine to get even 20 HP (or whatever it takes for cruise speed).
Another viewpoint on my ~2.7 throttle ratio between vaporized and atomized fuel:
Say the 'normal' engine RPM at cruise is 1800. The vapor engine would need 2.7x more fuel/air. That would take 2.7x the RPM (well, I'm not sure how the throttle plays into it - but ignoring that for now), which would be 4860, which is probably near peak HP (and efficiency) for that engine. So just another way to look at how it moves closer to peak BHFC efficiency.
NTL2009 said:
"Of course (also a boomer, if that matters?)
AKA, experienced, been around the block, heard the nonsense before, you can't fool me, etc. It's a introductory qualifier statement - old people understand this...
Let me add - I'm a boomer and a licensed Aircraft Technician (F.A.A Airframe and Power plant licensees) on top of that I'm a Mechanical engineer and License PE as well - 40 years+ experience. Oh ya, and I've done automotive fuel system and exhaust emissions control systems design and engineering.
Complete nonsense - it did not happen they were not getting 100 mpg out of a 427 cubic inch V8 1970 Ford Galaxy in 1977.
Atomize the fuel perfectly it will never happen - the math say no, the physics say no, the engineering says no and conservation of energy says no, and the con and urban story has been told over and over.
So called innovative fuel systems that perform miracles are nothing new. Either there's peer reviewed test results or not - and there NEVER IS VERIFIABLE TEST RESULTS.
digitalghost said:
.... Complete nonsense - it did not happen ...
I think you are missing the point of my post. I don't care if it happened or not, that's not my focus. I'm interested in "driving for answers"'s analysis. The idea that it is at least feasible that a large V8 could approach 100mpg with vaporized fuel (or not) is something I find interesting.
What math would rule it out? First, determine how much HP it would take to propel a vehicle that size at 45 mph. Again, assume the car maintained this slow, constant speed to reduce wind resistance, and assume a path chosen with no/few stops. Are you saying a 427 CI engine simply could not 'inhale' enough vaporized air/fuel to achieve that HP (taking into account the engine is likely running near it's most efficient BSFC)?
And as we have been discussing - in one way, it's not important if it is feasible or not, since the performance would be so poor, it isn't going to be implemented anyway. I'll repeat the lines I closed my OP with:
According to my googling, modern trains get ≈500 mpg per ton. I'm guessing Tom's galaxy weighed about 2 tons, so that would be ≈200 mpg per ton. Less than half as efficient as a train. Next!
There were one or more tricks involved in the 100 mpg demonstration with that big V8. Maybe the wind direction changed midday, so there was a negative air resistance each way. Maybe the tires were inflated to 100 psi.
100 mpg is more easily done outside the USA, because imperial gallons (4.546 litre), contain 20% more energy than US gallons, (3.785 litre).
If the fuel intake is less because it produces less power, then it is not more efficient.
If the "normal" car requires, say, 20 hp, to produce, say, 20 mpg, then for a fair comparison, the modified engine must also produce 20 hp for the 100 mpg claim.
When I drive at 30 mph on the highway, my MPG drops to about half what I usually do at 60 mph, because the power required to fight aerodynamic drag drops drastically. (Yes, I tried it.) There is no need to modify the fuel system to achieve such a claim.
BSFC would be more meaningful than MPG.
That being said, I assume he did not drive the car at 10 mph for his round trip to show everyone his car reached 100 mpg.
So it comes down to that claim:
Let us assume that the new fuel system burns every atom of fuel. If it can achieve a fuel consumption 5 times lower than the original car, producing the same power, then it means the original Detroit engine is burning only 20% of its fuel, with the remaining 80% passing through the exhaust system.
Does that seem logical? Do we believe that a 1977 engine was that inefficient? I don't think so.
Likes russ_watters, Lnewqban, Ranger Mike and 1 other person
I did not miss any point... I worked on teams designing both Compressed Natural Gas (CNG) as well as Propane - both fuels are a gas when entering the combustion chamber and there's a minimal (negligible) increase in fuel milage per unit of heat energy converted into mechanical energy due to the fuel being a "gas". The advantages of those fuels are in the emissions produced however be aware that there are other challenges associated with storage, safety and production costs of those fuels.
The inefficiencies of internal combustion engines are limited to the four and two stroke cycles - four stokes in a perfect world would be 25% maximum efficiency (100%/4) at the power output and reality is closer to 20%. Two strokes are less efficient.
There have been untold million of hours in engineering, design and scientific research and development on internal combustion engines. At this point squeezing more fuel efficiency out of internal combustion engines is like searching the couch for pennies. All strategies for increased fuel milage are smaller displacement and less mass to move around... Hybrids are a different discussion.
Have this conversation --- electric motors range from 75% up to about 95% efficiency in converting unit energy into mechanical power.
I'm done - good luck.
Likes russ_watters
