A A problem in multilinear algebra
  • A
  • Thread starter Thread starter steenis
    Algebra
steenis
TL;DR Summary
A one-to-one correspondence between bilinear non-degenerate maps and invertible linear maps
I have the following problem in multilinear algebra:
Let ##W## and ##V## be real finite-dimensional vector spaces, ##V^*## is the dual space of ##V##
Let ##L:W \times V \rightarrow \mathbb{R}## be a non-degenerate bilinear map
Define ##g:W \rightarrow V^*## by ##g(w)(v)=L(w,v)##
To prove: ##g## is an isomorphism
The map ##g## is obviously linear
##g## is injective, because if ##g(w)=0## for ##w \in W##, then for all ##v \in V## we have that ##g(w)(v)=L(w,v)=0##, so, because ##L## is non-degenerate, we have ##w=0##
Remains to prove that ##g## is surjective
If ##dim W=dim V=n##, then we are ready, because in that case ##dim W=dim V^*=n## and ##g## is surjective if and only if ##g## is injective. On the other hand, if ##g## is bijective, then ##g## is an isomorphism and ##dim W=dimV=dim V^*##. However, it is not a-priori given that ##W## and ##V## have the same dimension
Can anybody help me with this problem, can the statement be proven or is the statement not true?
You are correct. The difficulty is that we only can conclude ##\dim W \leq \dim V##.
What happens if you consider ##h\, : \,V\longrightarrow W^*## with ##h(v)(w):=L(w,v)##?
In the same way, ##h## is injective and therefore ##dim V \leq dim W##. Now we have ##dim W=dim V=dim V^*##, thus the map ##g## is surjective and therefore an isomorphism (##h## is also an isomorphism)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
