A pulley with rotational inertia
A pulley with a rotational inertia of 2.0 x 10^-3 kg·m² and a radius of 20 cm is subjected to a time-varying tangential force, F = 0.50t + 0.30t². The initial calculations for rotational acceleration and speed were incorrect due to a miscalculation of the radius, which should be 0.20 m instead of 0.02 m. After correcting the torque calculation and recognizing that the angular acceleration is not constant, integration was used to determine the correct rotational speed. Ultimately, the correct answers were found to be a rotational acceleration of 680 rad/s² and a rotational speed of 10.4 rad/s at t = 4.0 s. This highlights the importance of proper unit conversion and understanding the implications of non-constant forces in rotational dynamics.
soccer_09
A pulley, with a rotational inertia of 2.0 10-3 kg·m2 about its axle and a radius of 20 cm, is acted on by a force applied tangentially at its rim. The force magnitude varies in time as F = 0.50t + 0.30t2, where F is in Newtons and t in seconds. The pulley is initially at rest.
(a) At t = 4.0 s what is its rotational acceleration?
1 rad/s2
(b) At t = 4.0 s what is its rotational speed?
2 rad/s
Torque = I * alpha
Torque = |r||F|sin(theta)
I have only tried part a. What I did was since I know the radius = .020 m, F, and I, I rearranged the formulas like so:
alpha = Torque / I
Since it's tangent, sin(90) = 1 therefore Torque = r*F
F at 4s = 6.8 N and multiplying this by the radius .020 m gives a torque of .136 Nm
So now alpha = .136 Nm / .002 kgm^2 = 68 rad/s^2
I plugged that in on webassign and it was wrong so apparently I'm not doing something right. Any guidance is appreciated, thanks.
Your method for calculating the angular acceleration is correct. However 20 cm = 0.20 m not 0.02 m.
Yep, I had a friend tell me I converted incorrectly. Thanks :)
From there though, my alpha = 680 rad /s^2
The equation for rotational veloctiy is:
omega(t) = omega (initial) + alpha (t)
so with alpha = 680 rad/s^2 and t = 4s that should give me a rotational speed of 2720 rad/s
This, however, is incorrect as well. The initial omega = 0 rad/s because the pulley is initially at rest. What am I doing wrong here??
The equation omega(t) = omega (initial) + alpha (t) only works for constant angular acceleration. Here, force is F = 0.50t + 0.30t2, so alpha can't possibly be constant. You'll have to use integration to get the speed.
Thanks :) I integrated from 0 to 4 of F(t) and got 10.4. using the constants I and R, I was able to get the correct answer. Thanks again.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
