A Q About Electron Diffraction
Changing the energy of electrons in electron diffraction corresponds to altering their velocity, which affects their wavelength according to de Broglie's equation. By knowing the wavelength and the angle of diffraction, the distance between atoms can be calculated using the equation m*lambda=2*d*sin(theta). For determining the diameter of nuclei, a similar approach is used, applying the equation d*sin(theta min) = 1.22*lambda, where theta min is the angle of the first minimum. It's noted that typically, one does not vary energies to find crystal structures; instead, a single energy is used while scanning through angles to measure intensity. Understanding these principles is essential for effectively utilizing electron diffraction in atomic and nuclear investigations.
MA103
Q: Electron diffraction can be used to investigate both the arrangement of atoms and the dimensions of nuclei. Explain how changing the energy of the electrons can be used to achieve this.
I need help again, but this time, not alpha-scattering experiment but electron diffraction.
What I think is that changing the energy of the electrons is the same as changing the velocity of the electrons. If you know the velocity then you know the wavelength of the electrons, due to de Broglie's equation (lambda=h/mv). And if you know the velocity and the angle of diffraction, you can work out the distance between the atoms by the equation m*lambda=2*d*sin pheta. For the diameter of the nuclei it's almost similar except the end bit: you know the velocity of electrons, so you know the wavelength by de Broglie's equation. From the equation d*sin pheta min = 1.22*lambda you can work out the d, the diameter of the nucleus provided you got the wavelength (which has been calculated) and pheta min, the angle of the first minimum from the centre. I'm not sure about this. Also, am I answering the question?
Sorry I meant this :
What I think is that changing the energy of the electrons is the same as changing the velocity of the electrons. If you know the velocity then you know the wavelength of the electrons, due to de Broglie's equation (lambda=h/mv). And if you know the wavelength and the angle of diffraction, you can work out the distance between the atoms by the equation m*lambda=2*d*sin pheta. For the diameter of the nuclei it's almost similar except the end bit: you know the velocity of electrons, so you know the wavelength by de Broglie's equation. From the equation d*sin pheta min = 1.22*lambda you can work out the d, the diameter of the nucleus provided you got the wavelength (which has been calculated) and pheta min, the angle of the first minimum from the centre. I'm not sure about this. Also, am I answering the question?
You've mostly answered you own question. Often, however, you don't scan through various energies to find, say, the crystal structure. At a single energy (wavelength) you scan through various angles and measure the intensity as a function of angle. The structure can usually be determined from the Int. vs. theta plot.
PS : The equation you provided is called Bragg's Law - look it up for more info.
Thank you v. much. I'm going to read my physics book about what you said to learn more about them.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
