- #36
Fra
- 4,135
- 609
Hmmm, since when does thinking in those terms actually enlighten anyone?vanhees71 said:You have to think in terms of microcausal relativistic QFT to
![Big Grin :oldbiggrin: :oldbiggrin:](https://www.physicsforums.com/styles/physicsforums/xenforo/smilies/oldschool/biggrin.gif)
/Fredrik
I fully agree, the below is just for reflection and thought provocation...PeroK said:The thing you cannot do is pretend that somehow you can get round Bell's inequality and thereby recover realism, locality, and classical variables. That paradigm is gone.
To keep explaning my point in post #19, the problem with the premises of the theorem is that it assumes that the causality is randomly chosen from what would be the interaction from each "classical" possibility. This is the "ignorance" of the HV, that Bell's theorem assumes and shows does not work. (and it what i keeps reserving to)PeroK said:Assuming the only possibilities are heads and tails.
Is this your own personal theory, or is there a reference?Fra said:a more evolved(=more fit) strategy
If you want to get enlightened you need QED, the best description of light physicists have come up with, and that's a local relativistic QFT!Fra said:Hmmm, since when does thinking in those terms actually enlighten anyone?
/Fredrik
I am not sure everyone is 100% convinced that locality has gone. QM works perfectly experimentally; Bell's inequalities are violated, so at least one of Bell's assumptions must be dropped, and those are just facts. But I think we have every right and reason to suspect that QM is most likely not the final theory. Entanglement and the measurement problem are just two fascinating topics that could lead us into uncharted waters.PeroK said:The failure of Bell's theorem is not a problem for QM, because QM predicted it would fail in the first place. Don't underestimate the significance of this and why people who trust QM can't see the issue that others raise. Everything is as predicted by QM, so where's the problem?
This experiment is amazing. I was just thinking of an experiment on a circle with points A, S, and B equidistant (and the distance between A and B is less than half the circumference) in the order given. S is the source of preparation for the entangled particles, one of which is sent to A and the other (in the opposite direction) to B. If Bell's equations are violated this time as well, it would imply that one part of the wave function (with the measurement at A) collapses and the other part (of the particle travelling to B) survives a little longer. Or it would mean that particle B knows with certainty before the measurement what will happen in B (in case of measurements at the same axis).DrChinese said:And another experiment which is mind blowing to me: you can entangle 2 photons that have never existed at the same time. One photon is measured by Alice before the Bob photon is even created. (The entanglement itself is created after Alice's measurement, via entanglement swapping.)
https://arxiv.org/abs/1209.4191
It depends on, what you define as "locality". For me, as working in the HEP-nuclear physics community, locality means that relativistic QT is exclusively described by local relativistic QFTs, where locality means that by assumption the microcausality constraint holds, i.e., that local observables commute at space-like separation of their arguments. This holds particularly for the energy density and all other local observables, since energy density is a local observable, and this implies that there are no causal connections between space-like separated (measurement) events, i.e., relativistic QT is realized as a local QFT, and thus locality holds. What, of course, doesn't hold is "reality", i.e., as in any QT, also in relativistic local QFT not all observables necessarily take determined values.Tolga T said:I am not sure everyone is 100% convinced that locality has gone. QM works perfectly experimentally; Bell's inequalities are violated, so at least one of Bell's assumptions must be dropped, and those are just facts. But I think we have every right and reason to suspect that QM is most likely not the final theory. Entanglement and the measurement problem are just two fascinating topics that could lead us into uncharted waters.
It's not a theory, it is just my understanding/stance on the matter attempting to add perspective in the process of seeking a future better understanding (which is what we all want i think). But the key concepts of quantum vs classical strategies as beeing more or less fit, are not my personal ideas. I didn't have any specific paper in mind when writingn the post but see for examplePeterDonis said:Is this your own personal theory, or is there a reference?
Please be aware that personal theories are off limits here.
Quantum mechanics is doing just fine having performed flawlessly since inception. What more can one expect? What matters for a physical theory is to fit into the experiential reality.Tolga T said:But I think we have every right and reason to suspect that QM is most likely not the final theory.
Not everyone is convinced the Earth is a sphere and not flat. You'll never convince everyone of anything.Tolga T said:I am not sure everyone is 100% convinced that locality has gone.
I don't see how this relates to the thread topic. (I'm also not sure your description of what the paper says is correct.) If you want to discuss this paper, you need to start a separate thread in the appropriate forum.Fra said:The idea from above is that two interacting systems are better off (evolutionary perspective) if their strategy is based not on a simple either or, and always gor for the maximum short term benefit but also account for the expected backreaction from the environment
Very enlightening indeed!PeroK said:Not everyone is convinced the Earth is a sphere and not flat. You'll never convince everyone of anything.
Keep in mind that when it comes to the foundations of quantum mechanics there is more than one meaning to the terms "locality" and "non-locality". I don't think that anyone (aside from crackpots) has any doubt about Bell's theorems, that QM predictions violate Bell's inequality, and that experiments confirm QM predictions. Then it seems that there are people who are convinced about one of the possible interpretations of all that. From everything is local (in some sense of the word) to QM is definitely non-local (in some sense of the word).Tolga T said:Very enlightening indeed!
"That one body may act upon another at a distance through a vacuum without the mediation of anything else, by and through which their action and force may be conveyed from one another, is to me so great an absurdity that, I believe, no man who has in philosophic matters a competent faculty of thinking could ever fall into it."
One of the greatest thinkers of mankind could not help writing this down. He was suspicious, and he was so great at it again, because it turned out that his law of gravitation, although more than adequate for most applications, had to be replaced by a new theory after more than 200 years by an insurgent.
https://www.physicsforums.com/threads/collection-of-science-jokes-p2.847743/post-6808481PeroK said:Not everyone is convinced the Earth is a sphere and not flat. You'll never convince everyone of anything.
Neither of us can claim to know what Newton would have said about QM, had he lived in the late 20th Century. Nor can either of us say whether the failure of Bell's theorem would have changed Einstein's mind. The remaining alternatives to orthodox QM may have offended him more than QM itself.Tolga T said:Very enlightening indeed!
