A question about Simple Harmoic Motion
  • Thread starter Thread starter wowolala
    Motion
To find the period T of the simple harmonic motion described by Z(t)=(5)Sin(2∏/3t), the constant multiplier in the sine function is identified as 2∏/3. The standard period of a sine function is 2π, which is modified by the constant K, resulting in a period calculated as T = 2π/(2π/3). This simplifies to T = 3 seconds. Therefore, the period of the motion is 3 seconds.
wowolala
Let Z(t)=(5)Sin(2∏/3t) in SHO
guys, who knows how to find the Period T from above equation ?
thx
Read this: http://hyperphysics.phy-astr.gsu.edu/hbase/shm.html"
ooooooo... let's see...
The constant in this sin function is 2*pi/3 right? Since a regular sin function has a period of 2 pi and a constant K multiplier reduces the period to 2pi/K, and K in your situation is 2*pi/3... then...
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
