A question in the energy of a capacitor
  • Thread starter Thread starter ehabmozart
    Capacitor Energy
The energy stored in a capacitor is the work done to charge it, primarily performed by the battery, which acts against the electric field. The integral ∫ V dq represents the energy stored, where V is the voltage across the capacitor and dq is the infinitesimal charge. The confusion about the sign arises from the perspective of work done by an external force, which is positive. The relationship V = q/c helps clarify why the integration is set up this way, as it focuses on charge rather than voltage. Ultimately, the integration limits are typically defined by the final charge on the capacitor, making ∫ V dq the preferred formulation.
ehabmozart
The energy stored in a capacitor is defined as the amount of work required to charge it. Can anyone clarify to me who does this work? It sure must be opposite to the electric field. In the derivation why is it ∫ v dq ... I don't get this integral. Why isn't it negative?? Thanks!
Why do you think it should be negative?
The battery is doing work. Vdq is the infinitesimally small amount of energy dU stored.
So is it because potential energy is the work done by an external force?.. I think I got it.. But why is it V dq and not for example Q dv?
Why don't we make something like integral of dq*dv ?
Here's my understanding of it: We have for the voltage across a capacitor:
V = \frac{q}{c}
And the equation for the power being spent, being turned into energy (stored in the capacitor) is:
P = IV
Now, integrate both sides with respect to time, on the left hand side we get the energy stored in the capacitor, and on the right hand side, we get:
\int V I dt
and since I = dq/dt that means our equation equals:
\int V dq
You could instead write Q dV But usually in problems, we are told what the final charge on the capacitor is, so we want our limits to involve charge, not voltage.
Susskind (in The Theoretical Minimum, volume 1, pages 203-205) writes the Lagrangian for the magnetic field as ##L=\frac m 2(\dot x^2+\dot y^2 + \dot z^2)+ \frac e c (\dot x A_x +\dot y A_y +\dot z A_z)## and then calculates ##\dot p_x =ma_x + \frac e c \frac d {dt} A_x=ma_x + \frac e c(\frac {\partial A_x} {\partial x}\dot x + \frac {\partial A_x} {\partial y}\dot y + \frac {\partial A_x} {\partial z}\dot z)##. I have problems with the last step. I might have written ##\frac {dA_x} {dt}...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
