MHB A question on consistency in propositional logic.
The discussion centers on a theorem in natural deduction regarding the inconsistency of hypotheses. It highlights a specific case where the set H contains a single atomic proposition p0, leading to the conclusion that {p0} implies ~p0, which is deemed impossible. Participants clarify that the theorem requires negation of phi, and in this case, phi should be p0, resulting in {p0} implying p0 instead. This correction emphasizes the importance of correctly applying the theorem's conditions. The conversation concludes with an acknowledgment of the misunderstanding in the initial application of the theorem.
Mathelogician
Hi everybody!
We have a theorem in natural deduction as follows:
Let H be a set of hypotheses:
H U {~phi) is inconsistent => H implies (phi).
Now the question arises:
Let H={p0} for an atom p0. So H U{~p0}={p0 , ~p0}.
We know that {p0 , ~p0} is inconsistent, so by our theorem we would have:
{p0} implies ~p0.
Which we know is impossible.(because for example it means that ~p0 is a semantical consequence of p0).
Now what's wrong here?
Thanks
Well, your theorem or schema is negating the phi, which you're not doing. In your example, you should end up with {p0} implies p0. No doubt Evgeny can correct any mistakes I just made.
You are right. If we apply the theorem to H U{~p0}, then phi from the theorem is p0. Therefore, the theorem concludes that {p0} implies p0.
Oooooooops!
I was reading a Bachelor thesis on Peano Arithmetic (PA). PA has the following axioms (not including the induction schema): $$\begin{align} & (A1) ~~~~ \forall x \neg (x + 1 = 0) \nonumber \\ & (A2) ~~~~ \forall xy (x + 1 =y + 1 \to x = y) \nonumber \\ & (A3) ~~~~ \forall x (x + 0 = x) \nonumber \\ & (A4) ~~~~ \forall xy (x + (y +1) = (x + y ) + 1) \nonumber \\ & (A5) ~~~~ \forall x (x \cdot 0 = 0) \nonumber \\ & (A6) ~~~~ \forall xy (x \cdot (y + 1) = (x \cdot y) + x) \nonumber...
