A question regarding power generation in MHD method
  • Thread starter Thread starter T C
    Power output
In the discussion on MHD power generation, the focus is on the impact of using a metal tube for an ionized flow compared to open flow. The key question is whether the confinement of the flow within a metal tube affects the power output generated. Factors such as the interaction between the ionized flow and the tube's material, as well as potential changes in magnetic fields, are considered. The consensus leans towards the idea that the tube could influence the efficiency and output due to these interactions. Ultimately, the scenario suggests that the environment and containment method can significantly affect MHD power generation outcomes.
T C
TL;DR Summary
If ionized flow is used to generate power/electricity by MHD method, will there be in any difference in power output if the flow is confined inside a tube made of metal instead of a free flow.
First, I want to put forward an imaginary scenario where an ionized flow is being used to generate power/electricity by MHD power generation method. The temperature of the ionized flow is the same as the surrounding atmosphere. Power/electricity is generated as the flow is ionized. Now, if the flow passes through a tube made up of metal instead of flowing in open, I want to know whether there will be any difference in power output in such a case or it will be the same?
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
Thread 'Electromagnet magnetic field issue'
Hi Guys We are a bunch a mechanical engineers trying to build a simple electromagnet. Our design is based on a very similar magnet. However, our version is about 10 times less magnetic and we are wondering why. Our coil has exactly same length, same number of layers and turns. What is possibly wrong? PIN and bracket are made of iron and are in electrical contact, exactly like the reference design. Any help will be appreciated. Thanks. edit: even same wire diameter and coil was wounded by a...
