A rock, the earth, an ellipse and the joys of angular momentum
The discussion revolves around a mechanics problem involving a rock of mass m orbiting the Earth with mass M and radius R, focusing on angular momentum (L) and energy (E). Participants explore how to express L in terms of r and E, emphasizing the relationship between angular momentum and the tangential velocity at the nearest point to Earth. The conversation also touches on deriving the escape velocity, noting its independence from the direction of launch when total energy is zero. Key equations, including the Vis Viva equation and energy relationships, are discussed to clarify the concepts. Overall, the thread aims to deepen understanding of orbital mechanics and angular momentum.
BigRedRod
I understand that this is a bit cheeky but I've found a problem on one of my mechanics problem sheets that is giving me a headache. As much as I could just ignore it I'd rather try and gain some more understanding of the vague world of rotation and orbit
part 1 said:
A rock of mass m orbits Earth, mass M, radius R with angular momentum L and energy E. Argue directly, considering the direction of motion at its nearest point r to the Earth's centre, that L can written r*sqrt(2m(E + GMm/r))
Even at this early stage I'm bewildered and my searchings and own ponderings still leave me confused. If anyone can quite highlight how L can progress anywhere beyond the obvious r x v (where x is the cross product, and v is the tangental velocity of the rock at it's nearest point to Earth) I'd be forever in their debt
For fun, here is the rest which flows from this first section
part2 said:
Solve for r, and by interpretting the two solutions, deduce the relation e = -GMm/(Ellipse Length)
part3 said:
Suppose the rock is set off by being thrown from the North pole at such a (very fast) speed to have total Enegy E=0 in a direction of our choice.
part4 said:
Conclude (without further calculation) that the escpae velocity is independent of throwing direction
I'm not asking people to do the question for me (although feel free ;) ), any general direction would be pretty damn useful
Thanks in Advance
Astronomy news on Phys.org
To answer your first part, we have
angular momentum L = mvr
energy E = 1/2(mv^2) - GMm/r
rearrange energy equation until you have v = something...
substitute that into L = mvr for v
multiply m into the squareroot and that's your answer.
Start with the Vis Viva equation.
V^2 = GM (2/R - 1/a)
The kinetic energy is
K = (1/2) m V^2
K = (GMm/2)(2/R - 1/a)
The gravitational potential energy is
U = -GMm/R
The total energy is
E = K + U
E = (GMm/2)(2/R - 1/a) - GMm/R
E = GMm { (1/2)(2/R - 1/a) - 1/R }
E = -GMm/(2a)
Notice that the expression for the total orbital energy, just above, is the answer to Part 2 of your homework problem.
Solve for the semimajor axis.
a = -GMm/(2E)
The angular momentum L is
L = R x mV
The magnitude of which is
L = RmV sin Q
Where Q is the angle from R to V. Since at periapsis this angle is pi/2 radians, the angular momentum in your homework problem reduces to
L = RmV
Refer again to the Vis Viva equation.
L = Rm sqrt{ GM (2/R - 1/a) }
Substitute the expression for (a) found above.
L = Rm sqrt{ GM (2/R + 2E/GMm) }
Rearrange terms.
L = Rm sqrt{ 2EGM/GMm + 2GM/R }
Simplify.
L = Rm sqrt{ 2E/m + 2GM/R }
Move the orbiting object's mass inside radical.
L = R sqrt{ 2Em + 2GMm^2/R }
Factor out the m.
L = R sqrt{ 2m (E + Gm/R) }
It looks to me as if Part 3 and Part 4 are really one question, and it is a trick question. An orbit with total energy equal to zero is, by definition, barely unbound having exactly the escape speed for its geocentric distance.
Jerry Abbott
Ah, ta muchly guys. That clears everything up
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
