A Simple Harmonic Motion Problem
The discussion focuses on a simple harmonic motion problem involving a uniform rod pivoted at one end, with two springs attached at the other end. The participants work through the equations needed to find the period of small oscillations and the velocity of the rod's endpoint as it passes through the equilibrium position. Key equations include the moment of inertia of the rod and the moments created by the springs and the rod's weight. The solution involves equating the moments to find angular acceleration and subsequently the period of oscillation. The final responses confirm the correctness of the calculations presented.
Faux Carnival
[PLAIN]http://img441.imageshack.us/img441/6951/physics.gif
As shown in the figure, one end (O) of a uniform rod of length L and mass M is pivoted to a wall. Two horizontal springs with force constants k1 and k2 are attached to the other end (P) of the rod. When the rod is aligned exactly along the vertical axis, the system is in equilibrium.
a) Find the period of small oscillations of the rod.
b) Assume that the initial angle the rod makes with y-axis is a small angle θ and the initial velocity 0. Find the velocity of the end point P of the rod as it passes through the equilibrium position.
Moment of inertia of a rod relative to its end: I = 1/3 ML2
I think I have a solution but it is too long and complex. I doubt it's correct. Any help appreciated.
Moment on the rod due to the spring is 2kl^2*theta. Equate it with I(alpha) then u will gte alpha and hence omega. From here u can proceed easily to find the period
That's what I did. But I added the moment from the mass of the rod too.
So k1L2θ + k2L2θ + MgLθ/2.
That's equal to Iα. (α being the second derivative of θ)
(k1L2θ + k2L2θ + MgLθ/2) / I is therefore w2.
That's part a. For part b, wmax = wθ and Vmax = wθL.
[PLAIN]http://img375.imageshack.us/img375/6378/captureoj.jpg
Are my answers correct? Thanks.
yes u r correct...
Thanks a lot Swap.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
