A sphere suspended from a cord -- Find the tension
  • Thread starter lola9
  • Tags
    Sphere
In summary, the problem involves determining the tension in a cord from which a sphere is suspended. The tension is influenced by the weight of the sphere and the angle at which the cord is positioned. By applying principles of physics, specifically equilibrium and trigonometry, one can calculate the tension in the cord based on the sphere's mass and the angle of suspension.
lola9
Find the tension
F=ma
I don't understand where F comes from because in the problem there is only the tension of the cord. And I have another question the forces along y-axis always be equal to zero? And why T cos q - m g = 0 equal zero? if it is along the X-axis
The statement of the problem clearly shows F as the force of the wind pushing the sphere sideways.
Also, it seems to me that the origin of the problem should more appropriately be wher the end of the T is and the arrow on the T should be in the other direction. That would follow the problem statement more than does the current drawing.
Note that the angle ##\theta## in the diagram is measured from the y-axis (not the x-axis). So, the y-component of ##T## is ##T \cos \theta## (not ##T \sin \theta##).
From equation 1 ? this T sin q - F = 0 (eq.1) ?
This is the equation for equilibrium in the x-direction. Is there something in particular about this equation that you don't understand?
why do you say that it is in equilibrium ? The wind is blowing right ?
Yes, the wind is blowing steadily toward the left which keeps the ball hanging at the angle shown. The ball remains in this position, so the ball is at rest. Therefore the ball is in static equilibrium. The three forces that act on the ball must add to zero. This means that the sum of the x-components of the three forces must add to zero and the sum of the y-components of the three forces must add to zero.
Likes Lnewqban and PeroK
so if the system is in equilibrium the forces along x and y will always be equal to zero ? How did you know that it is in equilibrium ?
Well, if you like you could assume that the wind is not steady and the ball is swinging all around, but then how would you possibly solve the problem? My point is that such simple mechanical problems always assume that things like wind are unchanging for the purposes of the problem so of course you take it as being in equilibrium.
Likes TSny
In equilibrium, the individual forces along the x direction are not zero, but the sum of the forces along the x direction is zero. That is, the sum of the x-components of the forces is zero. Same for the y direction.
Note that the problem statement says that the cord makes a constant angle. So, the angle is not changing.
Likes PeroK
so that is why the forces equals 0
That is why the sum of the forces equals zero. If an object remains at rest (in an inertial frame of reference) then the vector sum of the forces acting on the object must be zero.
Likes SammyS and erobz
ok thanks
Likes berkeman
FAQ: A sphere suspended from a cord -- Find the tension
What is the formula to find the tension in the cord?
The formula to find the tension in the cord is T = mg / cos(θ), where T is the tension, m is the mass of the sphere, g is the acceleration due to gravity, and θ is the angle the cord makes with the vertical.
How do you determine the angle θ in the tension formula?
The angle θ can be determined using trigonometric relationships based on the geometry of the setup. If the length of the cord and the height at which the sphere is suspended are known, you can use the cosine or sine functions to find θ.
What factors affect the tension in the cord?
The tension in the cord is affected by the mass of the sphere (m), the gravitational acceleration (g), and the angle θ that the cord makes with the vertical. Any change in these factors will alter the tension.
How does the length of the cord influence the tension?
The length of the cord itself does not directly influence the tension. However, it affects the angle θ, which in turn influences the tension. A longer cord generally means a smaller angle θ, resulting in a higher tension.
Can the tension in the cord ever be equal to the weight of the sphere?
No, the tension in the cord cannot be equal to the weight of the sphere if the sphere is suspended at an angle. The tension will always be greater than the weight because it has to counteract both the vertical component of the weight and provide the necessary centripetal force if the sphere is in equilibrium.
