A steel shuttle is pulled along a rail, what is its initial acceleration?
The initial acceleration of a steel shuttle pulled by a 25N tension force at a 45-degree angle is calculated using F/m = a, resulting in 32.89 m/s². However, the user encountered issues when attempting to find the x component of acceleration, leading to confusion about the role of friction. It was identified that friction must be considered, with a coefficient of 0.8 for steel on steel. The corrected acceleration formula incorporates this friction, adjusting the calculation accordingly. Understanding the impact of friction is crucial for accurate results in this scenario.
potatotimer
Question: a machine has a 760g steel shuttle that is pulled along a square steel rail by an elastic cord. the shuttle is released when the cord has a 25N tension at a 45-degree angle what is initial acceleration?
F = ma or F/m = a
it sounds like you just need to use F/m = a which gives 25 / .76 = 32.89 = a
this didn't work so I tried to get the x component of acceleration so I did 32.89cos(45) = 23.26 and this didn't work.
what am I missing, the force is tension right so it should be 25N?
potatotimer said:
Homework Statement:: Question: a machine has a 760g steel shuttle that is pulled along a square steel rail by an elastic cord. the shuttle is released when the cord has a 25N tension at a 45-degree angle what is initial acceleration?
Relevant Equations:: F = ma or F/m = a
Two possibilities come to mind. First, have you rounded to an appropriate number of significant figures? Second, have you been studying friction and, if so, would the friction of steel on steel come into play?
yeah its friction
rereading made me realize that friction does need to be considered which for a steel on steel collision u = 0.8
so the acceleration is 25cos(45) - .8*.76*9.8
thanks for the help :)
potatotimer said:
- .8*.76*9.8
Two errors in there.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
