A stone projectile hitting the target
In summary, the stone will cover the horizontal distance of 5 cm in the same time t as it falls, but it will also have a vertical displacement of -1/98 cm.
rudransh verma
96
A stone is thrown by aiming directly at the center P of the pic hanging on wall. The stone leaves the starting point horizontally with a speed of 6.75m/s and strikes the target at point Q 5cm below point P. Find the horizontal distance between the starting point of stone and the target.
$$(x-x0)=ut$$
$$(y-y0)=ut-1/2gt^2$$
$$y= -1/2gt^2$$
$$t^2=-1/98$$
If I get t I will be able to solve for x=ut
Correct, so you only need to find out how long it takes an object to drop 5cm. Since the stone is thrown horizontally, it is the same as just dropping it.
Nice LaTeX! :smile:
Likes rudransh verma
BTW, your last equations should be more like:
$$\Delta y = \frac{1}{2}g t^2$$
$$t^2 = \frac{2 \times 0.05}{9.8}$$
Since the motion and acceleration are in the same direction...
(EDIT -- Fixed error 0.005 --> 0.05 to represent 5cm)
Can I say the value given in the question of displacement is negative 5 cm.
Yes you can, but it's important to also then say that the acceleration of gravity "g" is pointing in the negative direction. Otherwise you end up with the square root of a negative number, which would give you an imaginary result (and would be wrong in this case).
$$t^2=-1/98$$
I guess you are trying to say that the stone will cover the horizontal and vertical distance in same time t
Likes berkeman
Yes. That is how many projectile motion problems are solved. Often, we use the constant horizontal velocity of the projectile and the known horizontal distance to solve for the time t, and then plug that back into the vertical motion equation (which has the quadratic term because of the constant downward acceleration of gravity) to find the vertical position.
In your current problem, things are a bit different, but we are still solving for the time t first to then use it in a 2nd equation.
FAQ: A stone projectile hitting the target
How does the weight of the projectile affect its impact on the target?
The weight of the projectile plays a significant role in its impact on the target. A heavier projectile will have more kinetic energy and therefore, a greater impact force on the target. This is why heavier projectiles are often used for more powerful and destructive impacts.
What is the relationship between the velocity of the projectile and its impact on the target?
The velocity of the projectile also has a direct impact on its impact force on the target. A faster moving projectile will have more kinetic energy and thus, a greater impact force. This is why projectiles are often launched at high speeds for maximum impact.
Can the angle of impact affect the damage caused by a stone projectile?
Yes, the angle of impact can greatly affect the damage caused by a stone projectile. A more direct impact (90 degree angle) will result in a deeper penetration and more damage, while a glancing impact (less than 90 degree angle) may cause less damage or even deflect off the target.
What factors can affect the accuracy of a stone projectile hitting the target?
Several factors can affect the accuracy of a stone projectile hitting the target, including the weight, shape, and aerodynamics of the projectile, as well as external factors such as wind speed and direction. The skill and technique of the person launching the projectile also play a role in its accuracy.
How does the hardness of the target surface affect the impact of a stone projectile?
The hardness of the target surface can greatly affect the impact of a stone projectile. A harder surface will result in a greater resistance to the impact, potentially causing the projectile to bounce off or break apart. On the other hand, a softer surface will absorb more of the impact, resulting in deeper penetration and potentially more damage.
