A system is always in a well-defined state, so the entropy is constant?
Entropy is fundamentally linked to the knowledge of a system's microstates versus macrostates. When a system's state is fully defined by the positions and momenta of its particles, it exhibits zero entropy, as described by Liouville's Theorem. In statistical mechanics, entropy variations arise when the individual particles are not tracked, leading to a reliance on macroscopic quantities. The discussion raises the question of whether the term "closed system" should be specified, indicating a potential nuance in understanding entropy. Ultimately, the distribution function, rather than just the Hamiltonian, uniquely determines entropy in statistical mechanics.
spocchio
This is my apparently-trivial problem, that probably means i don't understood what entropy is.
We all have faced the statement that entropy always increase.
With the power of statistical mechanics we can calculate the variation of entropy from two states, considering the difference of entropy of the final and the initial state.
To do it we suppose that the distribution of our system is
\rho=exp(-\beta H(q,p))
In the reality the distribution of a system is always a dirac delta in the phase space, and so there is no integral to do in the phase space to calculate entropy and so it is always constant.
\rho=\Pi_i \delta (q_i-q_{i,t})\delta (p_i-p_{i,t})
It seems to me that entropy depends on the knowledge that we have of the system. Observers with a deeper knowledge should see different variation of entropy, in particular, someone who know exactly the position and momentum of each particle should not see a variation of entropy.
Am I right?
Science news on Phys.org
Yes, you're exactly right. If the state of a system is specified completely in terms of the positions and momenta of each individual particle, it's called a "microstate". Such a state has zero entropy. If the state is specified in terms of macroscopic quantities such as density and pressure, it's called a "macrostate." A macrostate is a collection of microstates.
And even stronger, someone who follows the position and momentum of each particle will not see a variation of entropy. (Liouville's Theorem) Increase in entropy only happens when you fail to track the individual particles.
our system
Should you not add the word 'closed' before system?
nice question, I don't know the answer, what should change?
can we say that is not the knowledge of H(q,p) that gives the desired entropy?. In conclusion (in statistical mechanics) only rho(q,p) that determinate uniquely the entropy, with the request that \frac{d \rho}{dt}=0.
Been around 40 years since I took basic physics in college and while I remember doing some examples of insulation values / energy conduction, I doubt I could to the math now even if I could find the formulas. I have some some corrugated plastic sheet (think of the plastic signs you see on the side of the road) that is used in bee hives. Also have some used in a green house though a bit different in dimensions than this example but the general approach should still apply. Typically, both...
Problem: You’re an Uber driver with a Tesla Model 3. Today’s low: 30F, high: 65F. You want to reach a USD$ profit target in the least number of hours, but your choices could have added cost. Do you preheat the battery only when you are headed to the charging station (to increase the charging rate by warming the battery — however the battery might not be “warm enough” when your reach the charger and thus slower charging rates), or do you always “navigate to the charger” the entire day (which...
Thread 'Is Callen right in claiming dQ=TdS for all quasi-static processes?'
Hello! I am currently reading the second edition of Callen's Thermodynamics and an Introduction to Thermostatistics, and I have a question regarding Callen's definition of quasi-static. On page 96, Callen says: Another way of characterizing Callen's definition is that a process is quasi-static if it traces out a continuous curve in the system's configuration space. So far it's all well and good. A little later, Callen claims that the identification of $$TdS$$ as the heat transfer is only...
