A vertical cylinder fitted with a heavy leak-proof piston wi
The discussion focuses on a physics problem involving a vertical cylinder with a heavy leak-proof piston containing air. The key equation to solve for the mass of the piston is mg = PA, where P is the atmospheric pressure and A is the area of the piston. Participants express confusion about the forces acting on the piston, specifically identifying three forces: the weight of the piston, the pressure force from the air, and the atmospheric pressure acting on the piston. Clarification is sought on the correct labeling of these forces and the application of relevant equations. Understanding these forces is crucial for accurately determining the mass of the piston.
CLARA
HERE IS THE QUESTION
A vertical cylinder fitted with a heavy leak-proof piston with diameter 84.0 mm contains air (under the piston) of density 1.59 kg/m3 in thermodynamic equilibrium with the surrounding atmosphere, which is at 100 kPa and 39 oC. Determine the mass of the piston in kg, to three significant figures. Use gravitational constant g = 9.81 m/s2.[/B]
i tried to use PV=mRT for the air in the cylinder[/B]
mg= PA
I know there is a force due the the piston and the force due to the air
FPISTON = FAIR
FPISTON = mg
FAIR THIS IS WHERE IM STUCK IM NOT SURE IF MY WHOLE LOGIC FOR THIS QUESTION IS CORRECT. YOUR HELP IS GREATLY APPRECIATED[/B]
I am a bit confused by your naming/labelling of the forces and the equations you write.
To clear this :
There are three different forces that are acting on the piston. Which are these three forces?
11K
  • · Replies 20 ·
