Mikael17
- 43
- 4
Bob lives on top of a skyscraper which is 1000 meters high.
There are exactly 10 meters between 2 (glass) walls in his penthouse apartment.
Between these walls, - a photon moves back and forth (is reflected) for exactly 100 billion years.
Bob can measure the elapsed time to be 3153600000000000000 s
Based on the speed c, - Bob can also calculate the distance the photon has traveled = t x c = 946080000000000000000000000 meters.
Bob can both calculate and see (and count) that the photon travels 94608000000000000000000000 times back and forth between the 2 walls.
Because Bob knows the distance between the two walls and he has counted how many times the photon traveled back and forth, - and because Bob also knows the speed c , - it is easy for Bob now to double check and be 100% sure that the photon has traveled 94608000000000000000000000 meters.
Alice lives at the bottom of the skyscraper.
The entire skyscraper is built in glass.
From her apartment, Alice can look up into Bob's apartment and see that the 2 walls (between which the photon moves) in Bob's Penthouse are the same walls that continue 1000 meters vertically down and that they are the same walls that are in her apartment on 1st floor.
Alice can from here 1st floor apartments see and hear that the photons move between these 2 same walls as in Bob's apartment.
Because each time the photon turns around she gets a "beep" and a a light signal, - sent from Bob's apartment.
Alice also measures, just like Bob, the distance between these glass-walls to be exactly 10 meters (in her apartment) .
After exactly 100 billion years have passed (as the experiment took), Alice can see on her watch that it has lost 3153.6 seconds relative to Bob's watch.
Just like Bob, Alice has counted, - have seen / heard, - how many times the photon has moved back and forth, and completely agrees with Bob that it happened 946080000000000000000000000 times.
The problem is now that when Alice wants to calculate how far the photon has traveled, the distance will be : t x c - (3153.6 s * c) = less distance - compared Bobs calculation result, - of coursee because of the 3153,6 s time dilation.
The calculation shows that the distance the photon was traveling is much shorter than Bob has measured and calculated.
946080000000 meters has somehow been lost, - relative to what she herself has seen the photon travel with her own eyes.
What is the explanation for this?
Why don't Bob and Alice agree?
