A wood block is launched up a ramp
In summary, the conversation discussed the process of finding the vertical height and speed of a wood block launched up an inclined wooden ramp with given initial speed, mass, angle, and coefficient of friction. The summary included calculations for finding the normal force, friction, and acceleration in the x-direction, as well as determining the time and distance traveled by the block. The final calculation involved finding the component of gravitational force that will cause the block to slide back down the ramp and using it to determine the final speed of the block.
kenway
A 3 kg wood block is launched up an inclined wooden ramp that has an angle of 25° to the horizontal. the Block's initial speed is 12 m/s and the kinetic coefficient of friction is 0.2. What is the vertical height the block reaches above it's starting point? What speed does it have when it slides back down to its starting point?
What's listed first is what is given:
VO=12m/s
g=9.8m/s2
mass (m) = 3kg, which means
weight (w) = 29.4 N
μ=0.2
θ=25°
Then I found the x and y components of the weight:
wx = 29.4sin25 = 12.42 N
wy = 29.4cos25 = 26.65 N
The normal force and y component of the weight equal each other:
normal force (n) = wy
n=26.65 N
And by using the normal weight I found friction:
friction (f) = 0.2(26.65N) (μ*n)
f= 5.33 N
This is where I got stuck. I know if I find the acceleration in the x-direction of the block I can calculate the distance it traveled, which would give me the hyp. of the ramp (triangle) and I can use trig to find the y-comp. So if I find acceleration:
a = (wx-f)/m
a = (12.42 - 5.33)/3
a=2.63
This doesn't help because it should be negative. But then I read somewhere gravity is also acting as a resisting force, so then I modified my equation:
a = (12.42-5.33-9.8)/3
a = -0.90
But this seems low. I've tried altering that equation other times but I feel every time it is wrong. Could I get some guidance?
Hello. Welcome to PF.
kenway said:
This is where I got stuck... So if I find acceleration:
a = (wx-f)/m
Consider the directions of wx and f.
Likes kenway
They're both negative? So I would set it up as:
a = (-12.42 + (-5.33))/3
a = -5.92 m/s2
I wouldn't subtract the friction, because the two forces are adding on each other, so to say.
Then I can find time:
v = at
12/-5.92=t
2.03 s = t
Then I can plug all my variables into this kinematic equation:
x = x0 + vx0t + .5axt2
x = 0 + 0(2.03) + .5(-5.92)(2.032)
x = -12.20 m
This should give me the distance traveled by the block, or the hyp. of the triangle, but it's negative and that doesn't make sense. I'm not sure if the initial velocity (vx0) should be 12 though. If I plug 12 in for that, then I just add 24.36 to -12.20 and get 12.16 m. If that is the answer, then I can use this equation to find the height:
12.16sin25=y
5.14 m = y
And supposedly this is my answer. Does this look right?
a = -5.92 m/s2
Yes.
v = at
12/-5.92=t
2.03 s = t
OK
x = -12.20 m
Right, negative x indicates an error.
Likes kenway
As I described in the above paragraph, I tried again by plugging in 12 for the 0 (that you have highlighted) and got 12.16 m. If that is the answer, then I can use this equation to find the height:
12.16sin25=y
5.14 m = y
I think this is the answer
12.16sin25=y
5.14 m = y
I believe that's correct.
Likes kenway
So how do I calculate the second answer of the question: What speed does it have when it slides back down to its starting point?
I honestly don't even know where to start.
The block starts sliding from rest. Now, which force will make it slide and which force will oppose the sliding?
Likes kenway and TSny
Gravity causes it to slide, friction opposes it. So do I do it like this?:
a = (9.8-5.33)/3
Gravity - friction (found above) / mass
a = 1.49 m/s2
Then I would find the time it takes to get to the bottom? So:
y = .5at2
5.14 = .5(1.49)t2
sqrt(5.14/.0745 = t
2.63 s = t
Which I can then use in this equation:
v=at
v = 1.49(2.63)
v = 3.92 m/s
Friction is 5.33N, fine. But gravity is acting "along the incline" .Would it be 9.8? That's only acceleration and that too in the downward direction and not along the incline.
Likes kenway
Oh! So then I find the comp. that runs along the incline. So:
sin25=9.8/hyp
9.8/sin25=hyp
23.19
The hyp runs along the incline, but this seems like a high number. If it's supposed to be, then I will go with it, but when I plugged it into the equations I did in the last post I got 20.59 m/s for the final speed (I can do the math if you want to see), which seems high.
sin25=9.8/hyp
9.8/sin25=hyp
23.19
In the first part, component of gravitational force was resisting the block's motion by pulling it backward. That "same" force will now be causing it to slide. You've already calculated that in the first part, haven't you? And what you are taking as 9.8 is only the acceleration, not force as you haven't involved mass here.
Likes kenway
So that would be the x-comp. of the weight? I found:
mgsinθ = x
But that was the x-comp. of the block's weight, not gravity. If that's not the correct answer, then I did the first part wrong
Going up, the block had two forces acting along the incline and they acted in the same direction.
Going down, what two forces act on the block along the incline? What are their directions? Get the acceleration using the same method as you did in the first part.
Likes kenway
Going up, the block faced friction and it's own weight, but it's initial velocity overcame that.
Going down, it doesn't have the velocity, but the friction is now facing up, away from the direction the block is moving, and it's "weight" still faces down, which pushes it down the ramp, so to say. So:
a=(12.42-5.33)/3
a=2.36 m/s2
Plugging it into the equations, I got 4.91 m/s.
mgsinθ = x
Weight is a due to the gravity, isn't it?
The component of wight along the incline was resisting the block's motion in the first part. You did it right. Now the same force will make the block slide.
Likes kenway
a=(12.42-5.33)/3
a=2.36 m/s2
Your analysis is correct!
Likes kenway
Okay, this makes more sense now! Thank you both for all your help. I feel much more confident about this. I appreciate it very much!
Likes cnh1995
a=(12.42-5.33)/3
a=2.36 m/s2
OK. ( I guess you are now taking the positive x direction to be down the incline.)
Hmm. Did you use the correct distance of travel?
I used the y comp. of the ramp (that's what I used in the first equation, 5.14m), but I can see where that could be wrong. The length of the ramp (hyp of the triangle) would then be 12.16 m. Then to find the time:
sqrt(12.16/2.36/2) = t
3.21 s = t
v=at
v = 2.36(3.21)
v = 7.58 m/s
Looks good.
Likes kenway
3.21 s = t
v=at
v = 2.36(3.21)
v = 7.58 m/s
Right! That can also be done without involving time t. You can use,
v2=u2+2ax..
You have u=0, a=2.36, x=12.16m.
Likes kenway
Related to A wood block is launched up a ramp
1. How does the angle of the ramp affect the launch of the wood block?
The angle of the ramp affects the launch of the wood block by changing the amount of force required to launch it. A steeper ramp will require more force to launch the block, while a shallower ramp will require less force.
2. What is the relationship between the height of the ramp and the distance the wood block travels?
The height of the ramp is directly related to the distance the wood block travels. The higher the ramp, the farther the block will travel. This is because the higher the ramp, the more potential energy the block has, resulting in a greater distance traveled.
3. How does the weight of the wood block affect its launch up the ramp?
The weight of the wood block affects its launch up the ramp by altering the amount of force needed to launch it. A heavier block will require more force to overcome its weight and launch up the ramp, while a lighter block will require less force.
4. What role does friction play in the launch of the wood block up the ramp?
Friction plays a crucial role in the launch of the wood block up the ramp. Without friction, the block would not be able to gain enough traction to launch up the ramp. However, too much friction can also impede the block's movement, resulting in a shorter distance traveled.
5. How does the speed of the wood block at the bottom of the ramp compare to its speed at the top?
According to the law of conservation of energy, the speed of the wood block at the bottom of the ramp should be equal to its speed at the top. This is because the potential energy gained at the top of the ramp is converted into kinetic energy as the block moves down the ramp. In reality, the speed may be slightly less at the top due to friction and air resistance.
