Abel-Ruffini theorem: confusion regarding statement
In summary, the author discusses the concept of solubility by radicals in Galois Theory. The general polynomial of degree n is introduced as a universal polynomial with a universal property. The author defines solubility by "Ruffini radicals" and discusses its relation to the generic quintic. The author also talks about the gap in Ruffini's proof and how Abel filled it with his Theorem on Natural Irrationalities. The conclusion is that there cannot be a single formula that works for all polynomials of degree five or higher, leading to the non-solvability of the generic quintic.
winter85
35
Good day,
I am reading Stewart's Galois Theory (3rd ed). I'm up to chapter 8 where he starts tackling the issue of solubility by radicals.
The author considers independent complex variables [tex]t_1,t_2,...,t_n[/tex] and forms the polynomial [tex]F(t) = (t-t_1)(t-t_2)...(t-t_n)[/tex] which he calls the general polynomial of degree n. He says on p.95:
The reason for this name is that this polynomial has a universal property. If we can solve F(t) = 0 by radicals, then we can solve any specific complex polynomial equation of degree n by radicals. [...] The converse, however, is not obvious. We might be able to solve every specific complex polynomial equation of degree n by radicals, but using a different formula each time. Then we would not be able to deduce a radical expression to solve F(t) = 0. So the adjective "general" is somewhat misleading; "generic" would be better, and is sometimes used.
He let's [tex]L = \mathbb{C}(t_1,t_2,...,t_n)[/tex] be the field of all rational expressions in [tex]t_1,...,t_n[/tex] and defines K to be the subfield of L fixed by permutations of the roots. He remarks that in L the polynomial F(t) factorizes completely. He next defines solubility by "Ruffini radicals" as follows (he does mention it's not a standard definition): [tex]F(t)=0[/tex] is said to be solvable by Ruffini radicals if there exists a finite tower of subfields [tex]K = K_0 \subset K_1 \subset ... \subset K_r = L[/tex] where for [tex]j = 0,...,r-1[/tex] we have:
[tex]K_{j+1} = K_j(\alpha_j)[/tex] and [tex]\alpha_j^{n_j} \in K_j[/tex] for some positive integer [tex]n_j \geq 2[/tex]. The rest of the chapter is devoted to prove that no such tower exists when [tex]n \geq 5[/tex].
My question is this: it seems to me he does not answer the point raised in the paragraph I quoted above. So what is the EXACT statement of what Ruffini and Abel proved? did they only prove that the generic quintic is not soluble by radicals, ie, there is no one formula that works for all quintics? or did they prove that there are specific quintics over [tex]\mathbb{Q}[/tex] whose roots are not contained in any radical extension of [tex]\mathbb{Q}[/tex] ?
I know that the second case is true, and that it implies the first. But I want to know what Abel and Ruffini themselves proved, and whether the non solubility of the generic quintic implies that there are quintics over [tex]\mathbb{Q}[/tex] whose roots are not in a radical extension of [tex]\mathbb{Q}[/tex].
A second point, the book points out to the gap in Ruffini's proof that Abel filled by the Theorem on Natural Irrationalities. The book says:
Ruffini tacitly assumed that if F(t) = 0 is soluble by radicals, then those radicals
are all expressible as rational functions of the roots [tex]t_1,..., t_n[/tex]. Indeed, this was the situation studied by his predecessor Lagrange in his deep but inconclusive research on the quintic. So Lagrange and Ruffini considered only solubility by Ruffini radicals. However, this is a strong assumption. It is entirely conceivable that a solution by radicals might exist for which the [tex]\alpha_j[/tex] constructed along the way do not lie in L, but in some extension of L.[...] However, the more we think about this possibility, the less likely it seems. Abel thought about it very hard and proved that if F(t) = 0 is soluble by radicals, then those radicals are all expressible as rational functions of the roots — they are Ruffini radicals after all. This step, historically called Abel's theorem, is more commonly referred to as the Theorem on Natural Irrationalities.
I don't understand what is meant by that, or how the definition of "solvable by Ruffini radicals" is different from the standard definition of "solvable by radicals" which can be found in other algebra books, such as Fraleigh's and Jacobson's. If a polynomial over [tex]\mathbb{Q}[x][/tex] is solvable by radicals, how can its splitting field NOT be a radical extension? What is exactly the gap in Ruffini's proof and how did Abel fill it?
If anyone has Stewart's book or is familiar with this issue, I appreciate any help with clarifying these two points. Thank you.
The idea behind the procedure is, that a tower of field extensions with radicals corresponds to a tower of normal subgroups of automorphisms. This way we would get a tower for the alternating groups ##A_n## (generic polynomials). But all ##A_n## are simple for ##n\geq 5##, i.e. they cannot be solvable, i.e. there cannot be such a tower of normal subgroups, hence no tower of field extensions.
This means the assumption that there is a formula which works for all polynomials of a certain degree five or higher leads to a contradiction.
The problem with actual proofs is to get hold of the phrase "solvable by radicals". Certain polynomials can of course be solved, just let the ##t_i\in \mathbb{Q}##. But we need a formula for all possible ##t_i##, hence generic.
  • Sad
Likes complicatemodulus
Related to Abel-Ruffini theorem: confusion regarding statement
1. What is the Abel-Ruffini theorem?
The Abel-Ruffini theorem is a mathematical result that states that there is no general algebraic solution to the quintic equation (a polynomial equation of degree 5 or higher) using only the basic arithmetic operations and roots. In other words, there is no formula that can solve every quintic equation.
2. Why is the Abel-Ruffini theorem important?
The Abel-Ruffini theorem is important because it marks a major turning point in the history of mathematics. It was the first proof that showed the limitations of algebraic methods in solving polynomial equations, and it led to the development of new branches of mathematics such as group theory and abstract algebra.
3. What is the confusion surrounding the statement of the Abel-Ruffini theorem?
The main confusion surrounding the statement of the Abel-Ruffini theorem is that it is often misinterpreted as saying that there is no solution at all to quintic equations. This is not the case - there are still specific quintic equations that can be solved using other methods, such as the cubic formula or numerical approximations.
4. Are there any exceptions to the Abel-Ruffini theorem?
Yes, there are some exceptions to the Abel-Ruffini theorem. For example, there are certain quintic equations that can be solved using only radicals (square roots, cube roots, etc.), but these are very specific cases and do not invalidate the overall theorem.
5. How does the Abel-Ruffini theorem relate to the unsolvability of the general quintic equation?
The Abel-Ruffini theorem is the proof of the unsolvability of the general quintic equation. It shows that there is no general formula or method for finding the roots of any quintic equation using only the basic arithmetic operations and roots.
  • Linear and Abstract Algebra
  • Differential Equations
  • Math Proof Training and Practice
