I About comparison to experimental reference values
The discussion focuses on the challenges of comparing experimental measurements of physical constants, which inherently have uncertainties. It emphasizes the importance of treating reference values like any other measurements and suggests using statistical methods to assess agreement between values. The t-student test is mentioned as a potential method for comparison, raising questions about determining degrees of freedom in this context. The conversation highlights the need for careful error propagation when assessing measurement differences. Overall, the discussion underscores the complexity of validating experimental constants due to their associated uncertainties.
chastiell
Hi again, probably this seems to be a simply question, but in last days i becomes a really strange one.
We all know that there are many kinds of constants in physics, some of them, are found experimentally with great accuracy in too expensive projects, but no matter how accurate can be measured such constant, they still have uncertainty. So imagine we made an experiment were any constant of this kind is measured , charge electron, charge to mass ratio, Newton gravitatory constant , ...
How to achieve an hypothesis proof on this constants considering that they have uncertainty ?
I has been searching this on Internet, but the nearest answer is given by the comparison of two gaussian variables with the t student distribution using:
t={|\bar{X_1}-\bar{X_2}|\over \sqrt{{\sigma_1^2\over n_1}+{\sigma_1^2\over n_2}}}
where
\sigma_i^2
are the estimators of variance of each variable
but in this form is assumed that the values n_i are known , thing that is not true for the experimental reference values , and this restrict us to always use a mean value, what if we determine this by linear fit, nonlinear fit ?
You are correct to use statistical methods to do the comparison ... the same as with any two statistical variables.
There are a wide range of methods depending on the kind of data you have and what you want to be able to say.
Rule of thumb:
Reference values should be treated like any other measurement.
If you just want to see if two measurements agree, then take the difference and propagate the errors - if they agree then the difference will be within some stated confidence value of zero.
Rule of thumb:
Thanks for the answer it is really useful ! . After reading this, i thought the next question ... suppose that the t student test is used to do the comparison ... considering that experimental reference value is treated like any other measurent the number of degrees of freedom would be n or n-1 ?
How do you normally determine the degrees of freedom?
number of degrees of freedom ndf :
ndf = n-r
n : number of data
r : number of restrictions
usually in this kind of test i use r = 1
Then you have your answer.
Assume that this is a case where by sheer coincidence, two sources of coherent single-frequency EM wave pulses with equal duration are both fired in opposing directions, with both carrying the same frequency and amplitude and orientation. These two waves meet head-on while moving in opposing directions, and their phases are precisely offset by 180 degrees so that each trough of one wave meets with the crest of the other. This should be true for both the electric and magnetic components of...
