About the behaviour of a beam-splitter
  • Thread starter AnssiH
In summary, a beam-splitter is a device that splits a beam of light into two or more parts. It is commonly used in optical experiments and technologies, such as in interferometers and laser systems. The behavior of a beam-splitter is determined by its material and design, which can result in different outcomes such as partial or complete reflection and transmission of light. The exact behavior of a beam-splitter can be predicted and controlled through the principles of quantum mechanics and optics.
AnssiH
300
http://www.quiprocone.org/Protected/Lecture_2.htm
On the page you will find a video of Mr. David Deutsch talking about quantum computation, in terms of many worlds interpretation. At around 11:20 he mentions a curious feature about a beam splitter. He says that while a beam splitter makes the photon's direction of motion "unsharp", it can also do the reverse of that. I.e. if you pass a photon through a beamsplitter, and then have a mirror at both possible directions of the photon so that they reflect the photon back into the beam splitter, the photon will *always* end up back to the direction where it originally came from due to "an interference process" of some sort.
(Note: if you watch the whole lecture through, the final test setup is in fact this same setup of a beam splitter and two mirrors. I don't quite understand why at time 41:50 Deutsch makes a conflicting statement to the above, saying that the photon entering the beam splitter from two directions still has two possible directions of exit "...it again strikes the beam splitter, from which there are two possible directions of exit", although in fact the test setup he is talking about is still just two mirrors being aimed at a single beam splitter, and later he accounts the fact that the photon exits only at one direction, as an indication of many worlds).
In any case, this "joining" feature of a beam splitter is something that caught my attention. Do we know how and why does it work that way? What if you aim two different but identical lasers to a beam splitter from two different angles but from the same distance; will both of the laser beams end up exiting to a single direction, leaving one possible exit completely empty? If so, what decides which exit the beams take? Or is this something that only happens if you are to aim a single beam through a beam splitter and have it bounce back into a beam splitter over mirrors?
What happens physically at the mirrors for that matter; i.e. what does it mean to reflect a light beam?
Thanks
Anyone?
Is there a better category for the question?
The easy answer is that it works because "joining" is just "splitting" done backwards.
The longer answer is that this is an interference process. When a photon returns to the beam-splitter and split again, it interferes with itself. You can place the mirrors so that one of the beams will be eliminated through destructive interference. (You can elimiate whichever one you like, I think)
Mathematically, the beam splitter may have the following effect on beams coming from the left (|L>), bottom (|B>), right (|R>), and top (|T>):
|L> --> (|T> + |R>) / sqrt(2)
|B> --> (|T> - |R>) / sqrt(2)
|T> --> (|L> + |B>) / sqrt(2)
|R> --> (|L> - |B>) / sqrt(2)
So, if you fire a beam in from the left (|L>), it splits into:
Then, if you place the mirrors carefully, so that the state going back into the beam splitter is:
then the beam splitter turns that into:
((|L> + |B>) / sqrt(2) + (|L> - |B>) / sqrt(2)) / sqrt(2) = |L>
This experiment is certainly proof that quantum superposition is real. However, it sounds like David Deutsch is making the mistaken assumption that other interpretations cannot work with superpositions. In particular, it sounds like he's assuming the Copenhagen interpretation necessarily says "either the photon went one way, or it went the other way", which is not correct. (Superpositions are certainly more natural in MWI than in Copenhagen, IMHO)
This is certainly a seam in my knowledge; maybe someone else can explain!
Superpositions are a feature of the formalism; the solutions of the Schroedinger equation are waves which can superpose by their nature.
The only difference between the CI and the MWI is that CI says the wave collapses and MWI denies that it does. But then MWI has to explain in what sense they mean "M", which gets them into science fiction or mysticism, take your choice. MWI also has problems with the assumption that experienced reality is the wave function (which it has to be since there's no collapse).
Thanks to everyone for replying
Farsight said:
I recall the David Deutsche lecture was discussed on another thread, where I think his basic premise came over as explainable via simple interference. I'll see if I can find it.
Edit: this was it, see post #35
https://www.physicsforums.com/showthread.php?t=123590&page=3
Thanks! And "doh!" 180 degree phase shift, of course... :I This makes me believe that also in the case of pointing two different lasers into the same beam splitter, we can choose which way all the energy exits by adjusting the distances.
Yeah, it stroke me as a bit odd that he seems to assume that. Especially being that it is the whole original oddity of Copenhagen that it says there exists such a thing as a superposition. In fact I was just in a debate elsewhere about this very fact, when someone was claiming that this experiment is a proof for MW, which it certainly is not.
Yeah, well, also with CI, even though it says there is a wave collapse, it is impossible to actually define when and why it happens. I guess that's why Bohr talked about conscious observer and strange stuff like that.
And if we think about a regular double-slit experiment, there also the photon is passing through air molecules all the time. I would expect the light is actually refracted by the atoms of the atmosphere on its way to double-slit (being that the speed of light is lower than C through air), yet there is no wave collapse due to these atoms. So it seems to me that this experiment is already revealing the oddity regarding the concept of superpositions & wave collapse.
About photoelectric effect
Oh, and Farsight, you mention in the other thread:
I recall reading somewhere that the photoelectric effect was not necessarily a particle phenomenum after all. I'll start a separate thread asking if anybody knows about this.
I've been wondering the same, and in John Gribbin's book "Schrödinger's Kittens", he mentions at page 115 that indeed, at 1950 David Bohm showed that photoelectric effect is already explained by just what Planck said; that atoms accept energy in definite amounts, and that "strictly speaking it means that Einstein did not deserve the Nobel Prize, at least not for the work he was given it for."
Then he goes on to explain how the experimenters have nevertheless observed photons to really exist. Hopefully you can find the book from the library for the details. Page 115 onwards.
It should be noted that this is already the case in classical optics. The "secret" is (as is established in any good book on classical optics) the 180 degree phase difference between the transmitted and the reflected beam at the planar interface of a dielectric. In order to understand this setup, it is really much more helpful to look at the classical picture (and use that to fill in the quantum version of it, where the photons just follow the behaviour of a classical pulse in this case).
Be careful with Deutch's claims. Although I myself am rather sympathetic towards the many worlds interpretation (as many can testify here to their dislikings :-p ), it doesn't do any good idea any service by overselling it in a religious way as Deutch does.
No experiment can *prove* any interpretation of QM over any other. In fact, MWI is more open to falsification than another interpretation like Copenhagen, because Copenhagen has an extra free "parameter" which is the place of the Heisenberg cut. So at best an experiment could show MWI to be false.
Only if they are phase-locked. And if they are phase-locked, "photons" are not localised into one beam, but are in a superposition of the two beams.
Really, these issues are better understood first using purely classical optics.
Related to About the behaviour of a beam-splitter
1. What is a beam-splitter?
A beam-splitter is an optical device that splits a single light beam into two or more beams by reflecting and transmitting parts of the original beam. It is commonly used in scientific experiments, lasers, and other optical equipment.
2. How does a beam-splitter work?
A beam-splitter works by using a partially reflecting surface, usually a thin film of glass or a beam-splitting prism, to split a light beam into two parts. The reflected and transmitted beams will have different intensities depending on the angle of incidence and the properties of the beam-splitter material.
3. What are the different types of beam-splitters?
There are two main types of beam-splitters: plate beam-splitters and cube beam-splitters. Plate beam-splitters use a thin film of glass to split the beam, while cube beam-splitters use a prism to split the beam into two perpendicular beams.
4. What is the difference between a polarizing beam-splitter and a non-polarizing beam-splitter?
A polarizing beam-splitter splits light beams based on their polarization, while a non-polarizing beam-splitter splits light beams regardless of their polarization. Polarizing beam-splitters are commonly used in imaging and projection systems, while non-polarizing beam-splitters are used in interferometers and other optical systems.
5. How is a beam-splitter used in scientific experiments?
A beam-splitter is used in many scientific experiments, such as interferometry, spectroscopy, and microscopy. It can be used to split a beam of light into two or more paths, allowing for the comparison of different samples or the measurement of different properties of the same sample.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
