Absolute Magnitude Calculation, How?
To construct an H-R Diagram, absolute magnitudes are typically required, but apparent magnitudes can be used if the stars in a cluster are at a similar distance. The user has measurements of apparent magnitudes in blue and yellow filters but lacks distance information for the star cluster. A recommendation was made to explore worksheets available online for guidance on creating the diagram. The discussion clarified that for a star cluster, the assumption of uniform distance allows the use of apparent magnitudes directly. This approach simplifies the process of plotting the H-R Diagram without needing absolute magnitudes.
capcom
Hello everyone,
Glad to be a new member of this superb forum :)
In one of my physics classes, I have to construct an H-R Diagram. Now, this does not seems too challenging, and I'm sure it isn't.
I was wondering if someone could kindly guide me in the right direction without giving me an exact answer.
So basically, I have been given some info about a star cluster. I have been given measurements taken through blue and yellow filters and told that the top of the main sequence is at B-V = 0.50 and V = 23.48 and bottom at B - V = 2.74 and V = 23.08.
You see, the B and V values are apparent magnitudes. The way I understand HR diagrams, they require absolute magnitudes. I haven't been given any distances to the star cluster, so how can I find an absolute magnitude? The only info I have been given with regards to its location is that it is in the dir'n of a dust cloud in the milky way.
So any recommendations as to how I should approach this. Thanks a lot everyone :)
Astronomy news on Phys.org
Thanks for your reply!
Actually, it turns out you can use apparent magnitude if the distance of the observed stars is the same.
We can consider the distance to be the same for a star cluster, so there we go - we can use the apparent magnitude.
Thanks again!
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
