Accelerated obserevers in special (not general) theory of relativity
In summary, the conversation discusses the possibility of considering accelerated observers in special relativity without using the mathematical language of general relativity, and the idea of introducing an additional axiom that states acceleration is irrelevant in relativity. It also brings up the effects of acceleration on space-time, such as length contraction and time dilation, and how they can be accounted for with formulas. The conversation also mentions the twin paradox and how general relativity explains gravity as equivalent to acceleration.
Nedeljko
40
Hi, folks!
I am interested for the following question:
The original Einstein's formulation of the special theory of relativity does not permit consideration of the accelerated observers, but this limitation is not essential because we can consider the special relativity as limit case of the general relativity by substituing gravitational constant by 0. Is it possible to consider accelerated observers in the special relativity without mathematical language of the general relativity (manifolds, tensors etc.)?
My idea is introducing following additional axiom:
Acceleration is relativistic irrelevant.
Let we consider two birds A and B, flying nonlinearly and nonuniformly with the motion laws A(t) and B(t) in inertial system S (of the ground), where A(t) and B(t) are indefinitely differentiable vector functions of the time. How the bird A see the bird B.
We will fix a moment [tex]t_0'[/tex] of the bird's A clock and compute [tex]t_0[/tex] such that [tex]t_0'=\int_0^{t_0}\sqrt{1-(A'(t)/c)^2}\,dt[/tex]. Then we compute the vector [tex]v=A'(t_0)[/tex] and fix the Innertial system S' such that S' has constant velocity [tex]v[/tex] relative to system S. Then we transform coordinates [tex](A(t_0),t_0)[/tex] of bird A to coordinates [tex](a',t_0')[/tex] in system S' and coordinates [tex](B(t_1),t_1)[/tex] of bird B to coordinates [tex](b',t_1')[/tex]. We compute moment [tex]t_1[/tex] using condition [tex]t_1'=t_0'[/tex], and position [tex]b'[/tex] using computed moment [tex]t_1[/tex]. Then, intensity of vector [tex]b'-a'[/tex] is distance bitween two birds measured by bird A when it scan the time [tex]t'[/tex] from it's clock.
Is it correct?
Special relativity can deal with accelerations just fine, you don't need GR for that at all. And it's not quite as simple as you think, because accelerations bend space-time quite a bit, even with "only" special relativity.
Remember how simultaneity depends on speed? Clocks run at different rates, lengths are different, etc... Well, imagine the changes when you accelerate.
Suppose you want to fly to a star which, before you start accelerating towards it, is 100 light-years away. If you accelerate to 0.8 c, the star will now only be 60 light years away due to length contraction. This means that, if you accelerate from 0 to 0.8 c in less than a year, the star will have moved more than 40 light years closer during that time. In other words, in your accelerating frame of reference, the star is moving at over 40 times the speed of light. This is quite possible since your reference frame is not inertial.
Also, clocks on the star will, again in your frame of reference, have moved forward by about two centuries (while clocks at the same distance behind you will actually have turned backwards). You don't actually see this happening, you just infer it because before and after the acceleration you see images of the same events while light will now have been under way for a longer time (only traveling at 0.2 c relative to the star), which means these same events must have happened longer ago.
(edit: I originally said "5 decades" and "0.4", but I had messed up by switching two figures around)
These effects are proportional to distance, so you can easily make the clocks on a distant quasar move back and forth a few seconds by simply jumping around in your living room. Funny but true. Of course other people in the room will say you're crazy because for them the quasar's clocks will just be ticking at their normal, slow rate. Until they get up for a cup of coffee.
This plays a role in the twin paradox: if you are the twin that moves away and comes back again, you will find your brother's watch has been ticking slower during the whole time you were away, except during the time you accelerated back toward him, which is precisely when his clock suddenly jumped forward, making you the one who turns out to have aged less when you return.
So I wouldn't say accelerations are irrelevant in special relativity at all!
General relativity just says gravity is equivalent to acceleration, so it causes the same kind of effects. Only, since the acceleration caused by gravity becomes smaller at a distance, the effects won't be quite as dramatic. But it does turn out to make clocks run at different rates depending on how high you are in the field of gravity.
And the (very hardy) people living on the quasar will say you're all crazy because they never experience anything unusual happening to them, no matter how you all jump around. :biggrin:
Nedeljko: Do you understand how classical, non-relativistic mechanics is able to deal with accelerating frames of reference? You can use exactly the same methods for SR...
@michelcolman
Thank you for your fast and detail answer, but it seems that you are not readed my post carefuly.
I know for all these effects and when I implement my idea to formulas for concrete cases, I find that the length contraction and the time dilatation are consequences of obtained formulas and I find nothing from your post that is not consequence of my formulas. Yes, if I accelerate to 0.8c I will see star as more near because length contraction and I can be near the star in arbitrary short my proper time because time dilatation, and I return from my journey to Earth for example 1 second older, but my frends from the Earth will be dead (because the time measured from the Earth must be longer than 200 years). I know it.
For example, if the bird A moved from the moment [tex]t_0[/tex] to the moment [tex]t_1[/tex] of the inertial system S (of the ground), then the adequate proper time of bird A is [tex]\int_{t_0}^{t_1}\sqrt{1-\left(\frac{A'(t)}{c}\right)^2}\,dt[/tex]. Is it correct?
If the bird A measured it's proper time [tex]t'[/tex], we can compute corresponding "earth's" time [tex]t_0[/tex] by solving the equation [tex]t'=\int_0^{t_0}\sqrt{1-\left(\frac{A'(t)}{c}\right)^2}\,dt[/tex]. I thinked that it is the easier part of my considerations.
Does anybody can show me what is mjy concrete mistake. The best is constructing an example where we obtain different results.
Also, clocks on the star will, again in your frame of reference, have moved forward by about five decades (while clocks at the same distance behind you will actually have turned backwards). You don't actually see this happening, you just infer it because before and after the acceleration you see images of the same events while light will now have been under way for a longer time (only traveling at 0.4 c relative to the star), which means these same events must have happened longer ago.
This is a little misleading, because you're making it sound like there is a single "correct" way for an accelerating observer to define simultaneity at each point on his worldline. It's certainly true that you can construct a "rest frame" for the accelerated observer in such a way that his definition of simultaneity at each moment will coincide with that of the inertial frame where he's instantaneously at rest (I think Rindler coordinates, which work as a rest frame for an observer experiencing constant proper acceleration, would have this property), and in that case everything you say is correct, but you don't have to construct the accelerating observer's "frame" in this way. Unlike for inertial observers, there is not really a "standard" convention for defining the rest frame of an accelerating observer, and thus no standard simultaneity convention either (and remember that simultaneity is just that, a convention, the question of what events are simultaneous from a given observer's 'point of view' is not really a physical question at all).
I can not believe that discussion started by me is so interessant for other members of the forum.
@JesseM
I understand your remark, but remember that scientific theory must be refudable, and that essential for scientific theory are measurable phenomens. If we compute any value different way using different definitions, but we have same observable predictions, then we have two images of the same scientific theory.
Consider we an airplane. Airplane is at airport in the city M, it starts acceleration, after any time it flies linearly and uniformely, and then it slows to land at airport in city N. Pilot and passanger (at distance [tex]d[/tex] behind pilot) has instruments for measuring accelerations. At different positions in same airplane pilot and passanger have different maximum of acceleration during accelerating from airport in the city M. This proposition is observable and it must be decidable by theory and independent on used definitions.
@JesseM
Can you give any support for that statement?
Where has it been observed?
Nedeljko said:
@JesseM
I agree, different coordinate systems don't represent different scientific theories, they all make the same predictions about localized events (like what two clocks will read when they cross paths, or what an accelerometer reads at the moment a clock next to it shows a certain time) and frame-invariant quantities (like rest mass or the spacetime interval).
Sure, accelerometers, which measure proper acceleration (the instantaneous acceleration in an object's inertial rest frame at that moment, which is proportional to the G-forces experienced), will always be predicted to give the same readings in every coordinate system, so if that's all you're saying I agree (HallsofIvy seems to think you're saying something else but I don't read your statement as anything more than a comment about proper acceleration being frame-invariant and measurable by accelerometers, let me know if I'm misreading you). But my response to michelcolman was specifically about the issue of how accelerating observers define simultaneity with distant events, which depends completely on their choice of coordinate system, it's not a frame-invariant quantity like proper acceleration is.
Hint: Proper distance between pilot and passanger is constant, but because motion, same distance measured from the ground is shorter (contraction of length). In inertial system of ground, passanger must be faster than pilot because decreasing distance. I can give complete computation for any concrete case.
This is the imagined experiment, not real. I am talkig about my prediction of value those does not depend on chosed set of definitions. This is observable value - it has same value in all images of the same scientific theory.
Nedeljko, you're just talking about Born rigid acceleration, right? The fact that observers experiencing such acceleration (in which the distance between any two observers remains constant in their inertial rest frame at every moment) will feel different proper accelerations is also discussed on this page:
We can imagine a flotilla of spaceships, each remaining at a fixed value of s by accelerating at 1/s. In principle, these ships could be physically connected together by ladders, allowing passengers to move between them. Although each ship would have a different proper acceleration, the spacing between them would remain constant as far as each of them was concerned.
Nedeljko said:
@michelcolman
Wouldn't those equations indicate that the bird's time and the Earth's time had both moved slower than the other? So when you put the clocks together, they would both have to be behind the other, which is impossible?
I may have misunderstood what you are writing, but it seems like you are considering the whole surface of the Earth as a reference, which is a bit difficult because time at different places on the surface will be moving at a different rate as observed by the bird. You have to compare with a clock at the point of departure/arrival of the bird. If the bird flies away from its perch and then turns around to come back, the clock next to the perch will have suddenly jumped forward during the turn. At first sight, I don't see that happening in your equations.
That is very true, indeed. My accelerating reference frame merely corresponded to the reference frame that would be used by an observer at the same speed who was not accelerating (so the transition is smooth when the acceleration starts/stops). It seemed to be a logical choice, but anyone is at liberty to pick any other kind of reference frame as long as he/she applies the required corrections.
[tex]A(t)[/tex] is the motion law of bird A in inertial system S (of the ground). In other systems we must calculate the bird's motion law.
If you were saying that acceleration of other objects doesn't matter to an unaccelerating observer, I think you are correct. So from an earth-bound observer's point of view, the birds can accelerate as much as they like, their clocks will only be affected by their speeds, not their accelerations.
The birds, however, will see clocks going back and forth around them all the time as they accelerate in different directions.
Hi Nedeljko! :smile:
Special relativity can be combined with the equivalence principle, and it does give many of the results "of general relativity".
For example, SR plus EP gives correct results for both geodetic and gravitomagnetic precession (ie, rotation of an observer's frame), at least in the "weak" case …
see, for example, K. Nordtvedt's "Special Relativity Equivalence Principle", pp. 71-94 in the unpromisingly-titled book "Gravitation: From the Hubble length to the Planck length" (2005).
The equivalence principle is only a local principle, and therefore its combination with special relativity does not give correct global results, such as for precession of the perihelion of Mercury …
this is why Einstein needed to invent general relativity. :smile:
I attached my computation in the attachment. The [tex]\LaTeX[/tex] source is in the attached zip file. My question is: Is this computation correct or not? If it is incorrect, why?
tiny-tim
Special theory of relativity does not include the gravitation. By this reason, the only prediction Mercury's motion law by the special theory of relativity is the straight line, but not a bounded path. By this reason, the general theory of relativity is introduced because including the gravity.
I wish use my idea for accelerated systems without gravity effects. Have I this way the same results as in general relativity with gravitational constant equal to 0.
  • Bird.pdf
  • Bird.zip
Ken Nordtvedt
Well, http://en.wikipedia.org/wiki/Ken_Nordtvedt" :wink:) would disagree with you.
Special relativity does not exclude gravity …
so you can add in the equivalence principle …
and if you do, special relativity then gives correct local gravitational results.
I am confused now. Is it true or not that the special relativity is limit case of the general relativity with G=0?
I'm also confused :confused:
isn't G just the conversion factor which converts mass to an equivalent distance?
(so, for example, the Schwarzschild radius RM of a mass M is a length, but can be written, in terms of mass, 2GM)
May be we have different understandig (definitions) of the special theory of relativity. I consider the special relativity as the limit case of the general relativity with G=0. What definition you use? Relativistic theory in the flat spacetime?
Can anybody tell me is the computation attached at the first post of this page correct or not and why?
I think the special theory is usually understood as the limit when you zoom in on an arbitrarily small neighborhood of a point in curved spacetime--this is the basis for the equivalence principle--or the limit as the curvature of spacetime (and thus the tidal forces) goes to zero, which happens naturally in the limit as the size of the patch of spacetime you're looking at approaches zero.
It isn't a great idea to attach the calculation in a pdf file. It's too hard to include bits of the math in quotes. I'll just comment on what you did in #1.
So far so good. Note that t0 is just the time coordinate in frame S of some event on A's world line.
Nedeljko said:
Then we compute the vector [tex]v=A'(t_0)[/tex]...
This isn't a vector (when we're considering 1+1-dimensional spacetime), but you already know that.
Nedeljko said:
...and fix the Innertial system S' such that S' has constant velocity [tex]v[/tex] relative to system S. Then we transform coordinates [tex](A(t_0),t_0)[/tex] of bird A to coordinates [tex](a',t_0')[/tex] in system S' and coordinates [tex](B(t_1),t_1)[/tex] of bird B to coordinates [tex](b',t_1')[/tex].
This makes S' a co-moving inertial frame (co-moving with A at time t0 in frame S). That's fine, but your presentation is a bit weird because you talk about transforming a point on B's world line before you specify which point, but I see that you're doing that next.
You have chosen to consider two events (one on A's world line and one on B's world line) that are simultaneous in S', which is the frame that's co-moving with A, so yes, b'-a' is the distance in S' between the birds at time [itex]t_0'[/itex]. But before you say that this is what A measures you should think about how he measures it. If he e.g. measures the time it takes to bounce a radar signal off the other bird, the result isn't going to be b'-a'. The coordinate distance in the co-moving inertial frame only agrees with the radar distance in the limit where the size of the region of spacetime where the measurement is performed goes to zero.
Regarding the relationship between SR and GR...
If you set the stress-energy tensor (and the cosmological constant) to 0 in Einstein's equation, the solution you get is the Minkowski metric. So SR can be described as "what GR says about a universe that's completely empty". I think the limit G→0 accomplishes the same thing. It removes the coupling between the geometry and matter, and the effect is the same as removing the matter.
As JesseM pointed out, there's also a local equivalence between SR and GR, that holds no matter what the stress-energy tensor is.
There are two reasonable notions of "locally Minkowski".
(1) The most commonly used is that at each individual point, the metric has signature +---. This means the tangent space at a point has the same geometry as (the tangent space to) Minkowski spacetime. However, any region of space-time may exhibit (second-order) deviations from the predictions of special relativity.
(2) The other reasonable notion is that each point in space-time is contained in a region that has the same geometry as Minkowski spacetime. Within such regions, there is absolutely no deviation from the predictions of special relativity.
(3) The inverse notion is that of being "globally Minkowski" -- the entirety of spacetime has the geometry (and topology) of Minkowski spacetime.
I am pretty sure that most people mean (3) when they talk about special relativity. I would like to emphasize that (2) is more general than three, even in 'completed' spacetimes: for example, you can have cylinder-like and torus-like spatial slices. In such spacetimes, you get additional global phenomena that arise from the topology.
Forgetting about these global phenomena that distinguish case (2) from case (3) can lead to paradoxes, such as the cosmological twin paradox.
Setting the stress-tensor to 0 admits Minkowski as one solution... but not uniquely.
You get a bunch of other solutions called the "vacuum solutions", which includes [exterior-]Schwarzschild, for example. (To get Minkowski, you'll need the whole Riemann curvature tensor to be zero... not just Ricci [or Einstein].)
It seems to me that we could just define an event co-local to the accelerated observer and a co-moving inertial frame, then transform that event into any other inertial frame. Without spatial separation, there would be no lack of simultaneity between the frames, even if one is accelerated. And we could define as many such events as we choose, as often as we choose, and just use the standard simultaneity convention for inertial frames to transform from one inertial frame to another.
Einstein didn't specify a simultaneity convention when he analyzed accelerated frames in his writings, but he must have assumed that others would infer that he was using the same definition as in SR, and a local co-moving inertial frame for each event. Is there any other practical way to do it without inventing a new convention?
Al
Thank you for your answer to my question. Because the forum software eat one of my previous messages (non saved to local disk) I made the new post in [tex]\LaTeX[/tex], posted it as PDF with [tex]\LaTeX[/tex] source in the attached zip file. You can use the source for citing without typesetting formulas. I know for better forum software (very much).
I do not understand what is #1, but my feeling is that it is not important for understanding of the rest of your post.
Yes, I know that [tex]t_0[/tex] is the moment in the system S. But, what is wrong. I have think that it is correct formula for the proper time of bird i.e. time of the bird's clock from its pocket (the clock flying together with the bird). If this formula is incorrect what is correct. Interpretation is as follows
The bird flies with motion law [tex]x=A(t)[/tex] in inertial system S of the ground. In the moment [tex]t_1[/tex] of S, the bird meets a bridge. In the moment [tex]t_2[/tex] of S (after [tex]t_2[/tex]) the bird meets a stone. How much the bird is biologic older from meeting bridge, to meeting the stone? If the formula
[tex]\int_{t_1}^{t_2}\sqrt{1-(A'(t)/c)^2}\,dt[/tex]
is incorrect, what formula is correct?
Yes, I know it, and I am expected this question. It is related to this remark:
I am interesting for following: If I use the same ideas for computing frame-invariant quantities in another examples, can I obtain incorrect results?
Thank you very much!
You got caught by a safety feature; users are logged out automatically after a certain period of time. This is done because some users might use public computer, and might inadvertently walk away from the computer without logging out, leaving their Physics Forum account active. If a user is automatically logged out while composing a post, and the user then clicks Submit Reply, the post, unfortunately, is lost.
If you use your own private computer, you can avoid this by checking the "Remember Me?" box that is to the right of "User Name" at the time of log-in. Then, as long as you don't clear your cookies, you will stay logged in permanently. If you don't want to check the "Remember me?" box, there are a couple of work-arounds.
Keep a second Physics Forums browser window open. After finishing your post, but before submitting the post, switch back to the other window, refresh the browser, and look at the top right corner to see if you're still logged in. If you are not, then log in. Switch back to the post window and submit the post. You can ensure that you stay logged in by periodically switching to the non-post Physics Forums window and refreshing.
Alternatively, after finishing a post, highlight the entire post and do a Ctrl-c.
Post #1. At the top right of each post (not window), there is a post #. This post is post #30. The numbers give a convenient way to reference particular posts within a thread.
Another tip: when using latex within blocks of text, use the itex and /itex tags instead of the the tex and /tex tags. Use the tex and /tex tags for equations that are between, not within, bolcks of text.
For example in post #1, you wrote
"We will fix a moment [tex]t_0'[/tex] of the bird's A clock and compute [tex]t_0[/tex] such that [tex]t_0'=\int_0^{t_0}\sqrt{1-(A'(t)/c)^2}\,dt[/tex]. Then we compute the vector [tex]v=A'(t_0)[/tex] and fix the Innertial system S' such that S' has constant velocity [tex]v[/tex] relative to system S."
Using the itex and /itex tags, this looks like
"We will fix a moment [itex]t_0'[/itex] of the bird's A clock and compute [itex]t_0[/itex] such that [itex]t_0'=\int_0^{t_0}\sqrt{1-(A'(t)/c)^2}\,dt[/itex]. Then we compute the vector [itex]v=A'(t_0)[/itex] and fix the Innertial system S' such that S' has constant velocity [itex]v[/itex] relative to system S."
So, please give latex another try.
[edit]Any further discussion of these issues should take place either in the Forum Feedback & Announcements forum (the last forum on the main Physics Forums page), or by Private Message.[/edit]
  • #31
I didn't say that it's wrong. It's not. I just explained what t0 is because you didn't.
Yes, JesseM explained it very well.
I'm not sure exactly what you mean by "the same ideas", but it clearly doesn't matter what frame you use to compute something coordinate independent like "proper time".
  • #32
Let we assume that the observer's motion law is given in inertial system S. The ideas are:
1. Computing the time of inertial system as a function depending on the observer's proper time.
2. Computing values in inertial system S' co-moving with the observer in any fixed moment.
3. Considering these values as values measured by the observer in this fixed moment of the observer's time.
4. Expressing these values as functions depending on the observer's time.
That are brief description of the ideas. Consult the attached PDF for the example of computation. Can I use these ideas safely?
Related to Accelerated obserevers in special (not general) theory of relativity
1. What is an accelerated observer in special theory of relativity?
An accelerated observer is an observer who is constantly changing their velocity or direction of motion. This is in contrast to an inertial observer, who moves at a constant velocity in a straight line.
2. How does special theory of relativity apply to accelerated observers?
Special theory of relativity applies to both accelerated and inertial observers, as it is a theory of how objects move in space and time. However, it is more challenging to apply to accelerated observers because their motion is constantly changing.
3. What is the difference between an inertial and an accelerated observer in special theory of relativity?
An inertial observer moves at a constant velocity in a straight line, while an accelerated observer is constantly changing their velocity or direction of motion. This difference is important in special theory of relativity because it affects how time and space are perceived by the observer.
4. Can an accelerated observer experience time dilation?
Yes, an accelerated observer can experience time dilation, which is the phenomenon where time appears to pass slower for an object in motion compared to a stationary observer. However, the calculations for time dilation in special theory of relativity are more complex for accelerated observers compared to inertial observers.
5. How does special theory of relativity explain the twin paradox for accelerated observers?
The twin paradox is a thought experiment where one twin travels at high speeds in space while the other twin stays on Earth. When the traveling twin returns, they have aged less than the twin who stayed on Earth. Special theory of relativity explains this paradox by considering the different velocities and accelerations experienced by the twins, which affect how time is perceived by each twin.
