Accelerating Rockets in Different Frames of Reference
The discussion centers around a user seeking direct answers for an exam question related to special relativity without showing their work. Other participants emphasize that the forum does not support cheating and requires users to demonstrate their understanding before receiving assistance. The importance of applying learned concepts to solve problems is highlighted. The user acknowledges this policy and expresses gratitude for the guidance. Overall, the conversation reinforces the educational focus of the forum.
eden24
New poster has been reminded to show their work on schoolwork problems
Adithya is in a rocket with proper acceleration a0 = 3.00 × 108 m/s2 to the right, and Eddie is in a rocket with proper acceleration a02 to the left. Let the frame of Adithya’s rocket be S1, and the frame of Eddie’s rocket be S2. Initially, both rockets are at rest with respect to each other, and Adithya’s clock and Eddie’s clock are both set to 0.
- 1 At the moment Adithya’s clock reaches 0.75 s in S2, what is the
velocity of Adithya’s rocket in S2?
- 2 At the moment Adithya’s clock reaches 0.75 s in S2, what is the
acceleration of Adithya’s rocket in S2?
Source https://www.physicsforums.com/forums/advanced-physics-homework-help.154/
pls help me
You need to show us your best attempt at solving this problem. I guess you are studying SR, so you need to apply what you've learned.
well i just need the answer for my exam
so i don't need the solution
thanks for your help cause this is my first time here
Sounds to me like you are asking for us to help you cheat on that exam. That's not how PF works -- here you are required to show your work on the problem before we can offer tutorial help.
It isn't what we do on this site. We can help you learn but not to cheat!
ok i got it tks for that
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
