Accelerating Universe and the Loss of Mass
In summary, the conversation revolves around the idea that the universe's accelerating expansion could be fueled by a decrease in the amount of mass. The experts discuss various analogies and scenarios to explore this concept, including the effects of fusion and the laws of thermodynamics. However, it is ultimately concluded that the idea of mass loss causing the universe's expansion is not supported by scientific evidence.
MisterBig
27
I had a thought the other day that I would quite like feedback on:
Could the universes accelerating expansion be fuelled by the amount of mass in the universe decreasing? Is it possible that a black hole could become so massive that it tears away from/gets pinched off spacetime, how much mass would we be talking about? How would a galaxy that lost its central black hole behave?
Astronomy news on Phys.org
The expansion of space in an Friedmann universe filled only with matter and radiation (and no dark energy) does always decelerate. If you consider an universe filled only with matter and radiation and you imagine that some unknown mechanism is decreasing the amount of matter (or energy equivalent) in a comoving volume, then the effect will not be an acceleration of the expansion, but a decrease of the deceleration rate of expansion. You can think about it with the following analogy: if you send a rocket away from earth, it will start decelerating as soon as it has no fuel anymore. If you imagine a mechanism to decrease then the mass of earth, then the deceleration of the rocket will decrease, but it will never start accelerating away from earth.
Ah, yes. Thanks.
Interesting answer. However, in your analogy requires the rocket has run out of fuel. Let's tweak this analogy a little. Let's assume that you have two stars at some distance apart.
lets look at what is going on.
1. The stars have gravity that attracts them that generates a attractive force.
2. The stars are outputting solar wind in all directions. however there is a buildup of matter between the stars where the solar wind is pushing againse each other causings a pressure differential that is greater between the stars than outside the stars (causing a repulsive force.
3. The star is undergoing fusion which converts mass to energy. This does a few things.
a. Lessens the gravitational force between the two stars
b. Increases the effect that the pressure discussed in item 2 has on the object's acceleration.
c. If the star is in motion to start it causes the star to accelerate in the direction of motion due to the conservation of momentum. (ie some of the E=mcc energy goes into the kenetic energy in order go conserve momentum.)
So this goes back to the original question about the expanding universe. Is the release of energy from mass loss in combination with higher pressure inside the universe than outside add up to be grater than that of gravity?
Another related tidit. One would also assume that as the mass of the Universe decreases due to fusion the velocity required to escape the universe (ie expand forever) would decrease as well.
If I am in error in any of my assumptions or explanations I am not afraid of being wrong so please let me know.
What 'outside' of the universe do you have in mind? Energy loss, gravitational or otherwise, violates the laws of thermodynamics - which are still held in high regard by the scientific community.
Related to Accelerating Universe and the Loss of Mass
1. What is an accelerating universe?
An accelerating universe refers to the expansion of the universe at an increasing rate. This means that the galaxies and other objects in the universe are moving away from each other at a faster pace over time.
2. What is causing the acceleration of the universe?
The acceleration of the universe is believed to be caused by a mysterious force called dark energy. This force is thought to make up about 70% of the universe and has the ability to counteract the effects of gravity and push objects in the universe further apart.
3. How does the loss of mass affect the acceleration of the universe?
The loss of mass, specifically in the form of stars and galaxies, can contribute to the acceleration of the universe. As these massive objects age and die, they release their mass into the universe, which can then be used by dark energy to accelerate the expansion of the universe.
4. Can we measure the rate of acceleration of the universe?
Yes, scientists are able to measure the rate of expansion of the universe through various techniques, such as observing the light from distant galaxies and measuring their redshift. These measurements have shown that the universe is indeed accelerating.
5. How does the accelerating universe impact our understanding of the universe?
The concept of an accelerating universe has greatly changed our understanding of the universe. It has led to the discovery of dark energy and has raised questions about the ultimate fate of the universe. It also has implications for the study of cosmology and the origins of the universe.
