Acceleration across a frictionless surface
When an object is pushed on a frictionless surface, it accelerates according to Newton's second law (F=ma). Once the applied force is removed, the object stops accelerating and continues at a constant velocity, as per Newton's first law. For example, pushing a 100kg object with 200N for 2 seconds results in a final velocity of 4m/s. This velocity remains constant indefinitely on a frictionless surface after the force is no longer applied. The discussion clarifies the relationship between force, mass, acceleration, and motion in the absence of friction.
Sammy101
Hi, I am confused on the topic of friction. I thought of a question that I cannot answer.
What happens if you push an object with a certain amount of force and mass on a frictionless surface? According to F=ma, you will be able to get the acceleration of the object, but how will you know when the object stops acceleration? Will the object accelerate infinitely?
As soon as you stop applying force to the object it will cease accelerating. IE if you push a block, as soon as you take your hand off or stop pushing it will cease accelerating.
And so then it will just continue at a constant velocity right?
So, if you pushed on a 100kg object with 200N of force for 2s and then let go on a frictionless surface, the objects final velocity would be 4m/s because:
F=ma
200N=100kg(a)
a=2m/s^2
t=2s
velocity= 2m/s^2(2s) = 4m/s and that's how fast it would travel forever on a frictionless surface?
Yes, as soon as the force applied ceases, the object will continue at whatever velocity it was when you removed the force.
Thank you!
Newton's first law & 2nd law
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
