- 1,650
- 246
Two objects, both of mass "m", start out, at rest, a distance "h" apart (the radius of both objects is negligable). What speed will one of the objects have when they collide? (relative to the original "resting" speed)
The whole point (without going into why) is to solve the problem without using conservation of energy.
The problem should be solvable right? Everything you could possibly need to know is known, so it's reduced to pure math.
Despite knowing everything, I can't solve the problem.
This is how I've expressed the problem mathematically:
[itex]a=\frac{Gm}{(h-∫∫a.dt)^2}[/itex]
[itex]∫\int^T_0a.dt=\frac{h}{2}[/itex]
[itex]\int^T_0a.dt=x[/itex]
Where x is the final velocity that I'm solving for.
My question is, have I correctly set up the equations? And if so, what 'tools' are required to solve this?
Do I need to know about differential equations?
I have a feeling I'm not yet prepared to solve the problem, but I mainly wanted to know if this was the correct way to set up the problem?
And I wanted to know if there is another way of expressing the situation (mathematically) that makes it easier to solve?
