Acceleration Logic is this right?
  • Thread starter Thread starter circuscircus
    Acceleration Logic
The discussion revolves around calculating the acceleration of a speed skater who slows down while traversing a rough patch of ice. The initial speed is 8 m/s, and after slowing down, the skater moves at 6 m/s over a distance of 5 m. The attempted solution calculates acceleration as -1/5 m/s², but there is uncertainty about the logic used. It is suggested to consider the average speed during the slowdown to find the time taken for the 5 m distance. The conversation emphasizes the importance of using the average speed for accurate calculations.
circuscircus
A speed skater moving across frictionless ice at 8m/s hits a 5m patch of ice. She slows steadily then continues at 6m/s. What is her acceleration on the rough ice?
Not sure
6m/s - 8m/s = -2m/s * 1/5m = 1/10 s
-2m/s * 1/10s = -1/5m/s^2
I'm not sure if my logic follows through
I don't understand what you are trying to do. If you're trying to find the time it takes to traverse that 5m patch, consider the average speed of the skater during that time. Then you can use Distance = ave speed * time to find the time.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
