Acceleration of a car followed by abrupt stop
  • Thread starter Thread starter iluvpandas
    Acceleration Car
To calculate the acceleration of a vehicle that decelerates from 90 km/h to a complete stop in 13 seconds, the correct formula to use is a = (Vi - Vf) / T. The initial velocity (Vi) is 90 km/h, and the final velocity (Vf) is 0 km/h. However, it's crucial to ensure that the units are consistent; either convert time to hours or velocity to km/s. If the velocity remains in km/h, the acceleration will be in km/h², while converting to km/s will yield acceleration in km/s². Proper unit conversion is essential for obtaining the correct answer.
iluvpandas
What is the acceleration of a vehicle that changes its velocity from 90 km/h to a dead stop in 13 s?
i don't understand how to do this correctly
i know I am supposed to use the formula for acceleration [a= (Vi-Vf)/T] i plugged in 90 for the Vi and 0( the dead stop) for Vf after that i divided by 13 but the answer i got was wrong.
Double check your units.
you mean convert to meters?
No. Your velocity is given in km/h and your time is given in s; they need to coordinate before you can just plug them in. You need to either convert your time to hours (in which case acceleration units would be km/h2) or convert your velocity to km/s (acceleration would be in km/s2).
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
