Acceleration of a Pulley System: 100g & 120g Masses
To find the acceleration of a pulley system with 100g and 120g masses, the approach differs based on whether the masses are on a ramp or hanging vertically. If on a ramp, the equations involve tension and gravitational forces, allowing for the elimination of tension to solve for acceleration. In the case of vertical hanging, the equations simplify to m1a = Ft - m1g and m2a = m2g - Ft, leading to a formula for acceleration as a = (m2g - m1g) / (m1 + m2). It's important to show your work in future inquiries for better assistance. Understanding the setup is crucial for accurate calculations.
chathamchick
Okay...i did this lab where two different masses are on opposite ends of a string and hung over a pulley...how do i find the acceleration of the system if mass one is 100g and mass 2 is 120g. help! please...
Is this on a ramp?
Or are both massesvertical?
If they are on a ramp, and m2 is hanging off the ramp:
m1 -->
Fnet = Ft - Fgx (-Ff)
m1a = Ft - FgsinX (-Fnu)
m2 --->
Fnet = m2g - Ft
m2a = m2g - Ft
Equate both (m2a + m1a) to get rid of Ft. Then you can solve for a .
If they are both vertical:
m1: m1a = Ft - m1g
m2: m2a = m2g - Ft
This is correct if m2 is going downwards, and m1 is forced upwards. However, the answer will be the same either way.
Once again, m1a + m2a to eliminate Ft and find a.
m1a + m2a = m2g - m1g
a = (m2g - m1g) / (m1 +m2)
After typing this, i remembered i wasn't supposed to help you, since you have not shown any of your own work. Please next time, keep that in mind.
they are vertical...like hanging on a pole...
Refer to me edited post chathamchick.
Thread 'Struggling to make relation between elastic force and height'
Hello guys this is what I tried so far. I used the UTS to calculate the force it needs when the rope tears. My idea was to make a relationship/ function that would give me the force depending on height. Yeah i couldnt find a way to solve it. I also thought about how I could use hooks law (how it was given to me in my script) with the thought of instead of having two part of a rope id have one singular rope from the middle to the top where I could find the difference in height. But the...
