Acceleration of an Electron in a Uniform Electric Field
The discussion focuses on the acceleration of an electron in a uniform electric field, with calculations showing that the electric field strength is 250 V/m. The force acting on the electron is calculated to be approximately -4.005 x 10^-17 N. The resulting acceleration, derived from the force and the mass of the electron, is approximately 4.395 x 10^13 m/s². There was initial confusion regarding the presentation of the equations, which was clarified by separating them for easier verification. Overall, the calculations were confirmed to be correct after restructuring.
jnuz73hbn
An electron is placed in a uniform electric field between two parallel plates. The plates are separated by a distance
d = 2.0\;\text{cm}
and a potential difference of
U = 5.0\;\text{V}
is applied across them.
E = \frac{U}{d}
\quad
F = q\,E
\quad
a = \frac{F}{m}
E = \frac{5.0\;\mathrm{V}}{0.020\;\mathrm{m}}
= 250\;\mathrm{V/m}
F = q\,E
= (-e)\times E
= -(1.602\times10^{-19}\;\mathrm{C})\times250\;\mathrm{V/m}
= -4.005\times10^{-17}\;\mathrm{N}
|F| = 4.005\times10^{-17}\;\mathrm{N}
a = \frac{|F|}{m_e}
= \frac{4.005\times10^{-17}\;\mathrm{N}}{9.109\times10^{-31}\;\mathrm{kg}}
= 4.395\times10^{13}\;\mathrm{m/s^2}
Your last LaTeX line is confusing since you are setting all 3 equations equal (which they are not). ##E \neq qE## for example.
Let me try to separate your equations to make them easier to check:
$$E = \frac{5.0\;\mathrm{V}}{0.020\;\mathrm{m}} = 250\;\mathrm{V/m}$$
$$F = qE = (-e)\times E = -(1.602\times10^{-19}\;\mathrm{C})\times250\;\mathrm{V/m} = -4.005\times10^{-17}\;\mathrm{N}|F| = 4.005\times10^{-17}\;\mathrm{N}$$
$$a = \frac{|F|}{m_e} = \frac{4.005\times10^{-17}\;\mathrm{N}}{9.109\times10^{-31}\;\mathrm{kg}} = 4.395\times10^{13}\;\mathrm{m/s^2}$$
Now that I can see your calculations separated, I think your numbers are correct.
  • Agree
Likes jnuz73hbn and SammyS
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
