Acceleration of falling mass and tension in the cord
The discussion revolves around calculating the acceleration of a falling mass and the tension in a cord connected to a rotating wheel. The inertia of the wheel is determined using the formula I = Mk², resulting in a value of 2.26. The forces acting on the falling mass are analyzed, leading to the equations F(net) = mg - Tension and torque = Iα. The challenge lies in the presence of multiple unknowns, which complicates solving for acceleration and tension. The need for torque equations is emphasized to relate the linear and angular accelerations effectively.
skysunsand
A 25 kg wheel has a radius of 40cm and turns freely on a horizontal axis. The radius of gyration is 30cm. A 1.2 kg mass hangs at the end of a cord that is wound around the rim of the wheel. This mass falls and causes the wheel to rotate. Find the acceleration of the falling mass and the tension in the cord
I= Mk^2
a= \alpha r
I figured out the inertia, with that being I=25*.3^2 to get 2.26.
The downward force on the object would be mg-Ft
The upward force is just Ft, I believe.
But somewhere in there has to go acceleration, which is a=\alpha*.4
I think I need another equation to set everything to, but I don't know what to do...
eqn 1....F(net) = ma for the falling mass
eqn 2 ...torque = Iα for the rotating disk
a = Rα
Why do I need torque?
Without the torque equation you will end up with too many unknown quantities.
But torque is another unknown.
I have
Ft= 25*a
and
Torque = 2.25 * angular acceleration
And I have a=.4*angular acceleration
So if I solve for either of them, I still wind up with two unknowns in the equation.
skysunsand said:
...Ft= 25*a ...
What is this equation?
Force of the tension = mass times acceleration.
Should it be mass of the object?
so Ft= 1.2a
But either way, that doesn't solve my too many variables problem
F(net) = ma...for falling mass
But F(net) downwards = mg - Tension
therefore
mg - Tension = ma
1.2 x 9.8 - tension = 1.2a
In above we have still 2 unknows
But we also have torque = I x ang acc and linear acc a - R x ang acc
  • · Replies 18 ·
  • · Replies 21 ·
  • · Replies 59 ·
  • · Replies 18 ·
  • · Replies 33 ·
