Acetylation- acetic acid or acetic anhydride
  • Thread starter Thread starter Taryn
    Acid
In the experiment involving the production of p-acetylaminotoluene from p-toluidine, there is confusion regarding whether acetic acid or acetic anhydride is the acetylating species. Acetic anhydride is known to acetylate alcohols but often yields lower results, while the experiment achieved a high yield, suggesting acetic acid's involvement. The quantities used were 4ml of acetic acid and 6ml of acetic anhydride, prompting questions about how these amounts relate to the acetylation process. Understanding the acid-base reaction between acetic acid and toluidine may clarify the acetylating mechanism. Further analysis of the chemical interactions could provide insight into which reagent acted as the acetylating agent.
Taryn
I did an experiment in one of the labs and I have a question I need to figure out.
The experiment was the porduction of p-acetylaminotoluene, from p-toluidine.
My question is we used acetic acid and acetic anhydride, but which is the acetyalting species.
I thought of looking at the structures of them but that kinda just confused me more.
I know that acetic anhydride is used to acetylate secondary and primary alcohols sometimes, but it gives a lower yield.
I got quite a high yield so I thought that the acetic acid might have been the acetylating species.
If anyone could just point me in the right direction that would be gr8. I am goin to ask my demonstrator today but any help would still be much appreciated.
Have a look at the quantities of both chemicals you used, if that doesn't point you in the right direction post all the numbers here and I'll have a look at them for you.
I used 4ml of acetic acid and 6ml of acetic anhydride.
I don't know how knowing how much I put in shows which is the acetylating species?
acetic acid is an acid and toluidine is an amine base. What happens when you combine an acid with a base?
I don't get how to argue it. i can prove: evolution is the ability to adapt, whether it's progression or regression from some point of view, so if evolution is not constant then animal generations couldn`t stay alive for a big amount of time because when climate is changing this generations die. but they dont. so evolution is constant. but its not an argument, right? how to fing arguments when i only prove it.. analytically, i guess it called that (this is indirectly related to biology, im...
Thread 'How to find the pH of a galvanic cell (MIT OCW problem set)'
This is the final problem in this problem set from MIT OCW. Here is what I did to try to solve it The table cited in the problem is below We can easily spot the two redox couples that are in the electrochemical cell we are given. The hydrogen-based electrode has standard potential zero, and the silver-based electrode has standard potential 0.22. Thus, the hydrogen electrode, with the lower potential, is the reducing agent (ie, it is where oxidation happens) and is the anode. Electrons...
