Achievable orbit from launch location
  • Thread starter Thread starter ank_gl
    Launch Orbit
The discussion centers on the limitations of orbital inclination based on the latitude of the launch site, specifically Baikonur at approximately 46° E. It is established that while theoretically any orbit can be achieved, practical limitations exist due to fuel requirements for changing inclination, especially at low Earth orbit. The minimum inclination achievable from a launch site cannot be less than the latitude of that site, with launching eastward providing the lowest inclination. Additionally, launching north or south increases inclination, while launching westward maximizes it. Overall, the inclination affects payload capacity and fuel efficiency during launch.
ank_gl
Hi Astro gurus,
Is there any limitation on the inclination of the achievable orbit because of the latitude of the launch location? For example, latitude of Baikonur is roughly 46° E. Does that limit somehow the inclinations of the orbits that can be achieved from Baikonur?
I think there should be no limitation as it should be possible to achieve any velocity vector at some position, & hence any possible set of orbital elements should be possible. More so, if a ballistic missile can hit target in any direction, it means different sets of orbital elements are possible.
Astronomy news on Phys.org
As long as you have a big enough rocket. But for a given rocket, the payload capacity will depend on the inclination (and altitude).
Yes there are limitations. See:
http://spaceflight.nasa.gov/shuttle/reference/shutref/sts/launch.html
http://www.orbiterwiki.org/wiki/Launch_Azimuth
ICBMs don't necessarily try to achieve orbit. They are designed to fly extremely long ballistic paths from launch point to target.
ank_gl said:
Hi Astro gurus,
(bolding mine)
This is true. The limitations refer to the ability to launch directly into a particular orbit (in which case, the inclination can't be less than the launch latitude).
It's a pretty big limitation given the fuel requirements to change the inclination at low Earth orbit. You want your speeds to be as low as possible when you change inclination, and that usually means you want to be as far away from the Earth as possible when you change inclination.
While ballistic missiles don't actually complete even one orbit, you could still think of their trajectory as an orbit that just happens to intersect the Earth and, yes, they can have orbital elements. However, the inclination of those "orbits" will never be less than the launch latitude. Launching to the East gives you your minimum inclination. Launching either North or South increases your inclination. Launching due West would give you your maximum inclination - at least if you use 0 to 180 as your inclination range. If you're one of those people that refer to orbits as 80 degrees prograde or 80 degrees retrograde, then I guess 90 degrees would be your maximum inclination. (Terminology isn't completely standardized.)
Thanks Russ. So you mean that the limiting factor is the fuel?
http://spaceflight.nasa.gov/shuttle/...ts/launch.html
Thanks Steamking. Well, that doesn't answer my question. But anyways, good links.
Aha, that's what I think is the case.
I agree, but the cost you mentioned is for changing the inclination while in an orbit. I am talking about setting the initial conditions such that any orbit is achievable. But I do see why the minimum inclination is the latitude of launch location.
I kinda see why one would want to have the same inclination as the latitude, as the velocity of Earth would be added to the rocket velocity, provided one is launching prograde.
Thanks BobG
BTW, I found a nice link too touching a similar topic. http://orbitrax.com/?p=3061
Is a homemade radio telescope realistic? There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs. Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is...
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
