Acoustics - Critical Bandwidths ?
  • Thread starter Thread starter Radiohannah
    Acoustics
The discussion revolves around the confusion regarding the combination of sound wave intensities within one critical bandwidth. The user seeks clarity on whether to sum or average the intensities of two sounds that fall within this bandwidth. There is a misconception that summing the intensities leads to an excessively high value, conflicting with the understanding that combined intensity should be lower. Ultimately, the user resolves the confusion by realizing that the correct approach is to sum the intensities, correcting a previous misunderstanding related to logarithmic calculations. This highlights the importance of accurately applying mathematical principles when evaluating sound intensity.
Radiohannah
Hello!
I'm getting a bit confused with how to deal with sound waves that are within one critical bandwidth of each other.
I do not fully understand how you are meant to combine the intensities of sound waves when they lie within one critical bandwidth?! I would really appreciate some clarity as I am getting very muddled!
I understand that separately (out with a critical band) the sum of the individual intensities would be more than that of the combined (within one critical bandwidth) intensities. This is where my confusion arises, I don't understand how exactly you can combine these intensities to get the overall result (from which I could evaluate the intensity level) ...the material online seems to conflict...
Basically, if I have two sounds, in one critical bandwidth, I can separately deduce their intensities, but then to evaluate the total intensity, am I meant to sum them, or take an average? By summing them I get an enormous value, which doesn't seem to correlate with the idea that the overall intensity should be smaller. But this is the approach that I have been finding online.
Any ideas/help?!?
Thank you in advance
Hannah :-D :-D :-D
Solved it! It must be a sum, was mistaking my logs for lns :-(
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (Second part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8. I want to understand some issues more correctly. It's a little bit difficult to understand now. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. In the page 196, in the first paragraph, the author argues as follows ...
Thread 'Inducing EMF Through a Coil: Understanding Flux'
Thank you for reading my post. I can understand why a change in magnetic flux through a conducting surface would induce an emf, but how does this work when inducing an emf through a coil? How does the flux through the empty space between the wires have an effect on the electrons in the wire itself? In the image below is a coil with a magnetic field going through the space between the wires but not necessarily through the wires themselves. Thank you.
