MHB Act.ge.5 third angle of triangle
  • Thread starter Thread starter karush
    Angle Triangle
In triangle ABC, with angle A measuring 25° and angle B greater than 90°, angle C must be less than 65° to satisfy the triangle inequality. The possible measures for angle C from the given options are 12°, 15°, 45°, and 50°, as they all fall within the acceptable range. Angle 70° is not a valid choice since it exceeds the maximum limit for angle C. The discussion highlights the importance of understanding angle relationships in triangles. Correctly identifying the possible values for angle C is essential for solving this type of geometry problem.
karush
MHB
$\tiny{act.ge.5}$
ok you have 2 seconds to figure this one out:unsure:
This question has live answer choices. Select all the answer choices that apply. The correct answer to a question of this type could consist of as few as one, or as many as all five of the answer choices.
\item In triangle ABC, the measure of angle A is $25^o$ and the measure of angle B is greater than 90°. Which of the following could be the measure of angle \textbf{C}?
Indicate all possible values.
a.\ 12^o
\quad b.\ 15^o
\quad c.\ 45^o
\quad d.\ 50^o
\quad e.\ 70^o $
from observation I choose 4 possible but thot I would see what the replies would be
Mathematics news on Phys.org
$A+B > 115 \implies C < 65$
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
