MHB Adding in Base 20: 1HE1C +JDF0 = 2H7GC
  • Thread starter Thread starter karush
    Base
The discussion focuses on adding two numbers in base 20: 1HE1C and JDF0, resulting in 2H7GC. The calculation involves converting each digit to base 10 for easier addition, then converting back to base 20. The key steps include adding C and 0, F and 1, and E and D, which requires carrying over values when sums exceed 20. The final carry from adding H and J leads to the correct result of 2H7GC. This method emphasizes the importance of understanding base conversions for accurate arithmetic in non-decimal systems.
karush
MHB
Add in base 20
1HE1C +JDF0= 2H7GC from calculator
By hand I couldn't get the H
Using
A=10
B=11
C=12
D=13
E=14
F=15
G=16
H=17
I=18
J=19
K=20
Mathematics news on Phys.org
as we are not comfortable with base 20 let us convert to base 10 (digit by digit) and concert it back
1HE1C
JDF 0
2H7GC
C+ 0 = C OK
F + 1 = G OK
$E + D = (14 + 13)_{10} = 27_{10} = 17_{20}$ so 7 and carry 1
$H+J + 1 = (17 + 19 + 1)_{10} = 37_{10} = {1H}_{20}$ so H and carry 1
$1+1= 2$
learned this method in a CS FORTRAN class a long time ago ...
Let $x=20$
1HE1C = $x^4 + 17x^3 + 14x^2 + x + 12x^0$
JDF0 = $19x^3 + 13x^2 + 15x + 0x^0$
sum ...
$x^4 + (20+16)x^3 + (20+7)x^2 + 16x + 12x^0$
$x^4 + 20x^3 + 16x^3 + 20x^2 + 7x^2 + 16x + 12x^0$
$x^4 + x^4 + 16x^3 + x^3 + 7x^2 + 16x + 12x^0$
$2x^4 + 17x^3 + 7x^2 + 16x + 12x^0$ = 2H7GC
Let $x=20$
sum ...
that would be a little bit easier to remember!
karush said:
Add in base 20
First, C+ 0= C. That's the right-most "digit".
1+ F= 1+ 15= 16= G. That's the next "digit".
E+ D= 14+ 13= 27= 20+ 7= 17. The next "digit" is 7 and "carry the 1".
That may be what's keeping you from "getting the H".
H+ J= 17+ 19= 36 and "carrying the 1", 27= 20+ 17= 1H. The next "digit" is H and "carry the 1"
With that carry, the last addition is 1+ 1= 2.
That's how we get 2H7GC!
Using
A=10
B=11
C=12
D=13
E=14
F=15
G=16
H=17
I=18
J=19
K=20
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
