Adding resistor and capacitor in parallel
The discussion focuses on calculating the total impedance of a circuit with two 8-ohm resistors and a 3-ohm capacitor in parallel. The correct formula for impedance is Z = (1/8 + 1/8 + 1/j3)^(-1), leading to the expected result of 1.44 + j1.92. A participant clarifies that the impedance can also be expressed as 4 ohms and 3j ohms in parallel, resulting in the equation 1/Z = 1/4 + 1/3j. The confusion arises around the numerator 12j, which is derived from multiplying 4 and 3j. The final simplified impedance is confirmed to be Z = 12j/(4 + 3j).
obsolete
Hi all,
I am meant to find the total impedance across the circuit but am having trouble with one section of the circuit. This section comprises of 2 resistors and 1 capacitor in parallel.
The two resistors are 8 ohms each and the capacitor is 3 ohms. So the process is meant to be:
Z = ( 1/8 + 1/8 + 1/j3) ^(-1)
and the answer is meant to be: 1.44 + j1.92
I know it is really simple but I can't wrap my head around it at the moment and it's driving me insane! Any help much appreciated.
The secytion can be written as 4 ohms and 3j ohm are in parallel. Then
1/Z = 1/4 + 1/3j
Z = 12j /( 4 + 3j) . Now rationalise the denominator and simplify.
Thanks rl.bhat.
I am wondering though how did you get 12j for the numerator? I'm sure it relates to 4 x 3j = 12j somehow but I'm not sure why...
When you add 1/4 + 1/3j you get (3j + 4)/12j. This is 1/Z. therefore
Z = 12j/(4 + 3j)
Thanks a lot man!
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
