Adjoint of a Differential Operator
CoachZ
If the inner product is defined on V with dimension less than or equal to 3 as \left\langle f,g \right\rangle = \int_{0}^{1}f(x)g(x)dx, I'm trying to find D* such that \left\langle Df,g \right\rangle = \left\langle f,D*g \right\rangle, and I thought I had a closed form of D*. If {1, x, (x^2)/2, (x^3)/3}. Call each element e_i, i = 0,...,3 form a basis for V, then \left\langle Df,g \right\rangle = \left\langle f,D*g \right\rangle holds given D* is defined as i times the (derivative of g(x)) if g(x) has degree greater than 0, but I can't think of a closed form so that it will work for all elements. Does anyone have any suggestions?
Would \delta(x-1)-\delta(x)-D work?
\int_0^1 Df(x) g(x)dx = \int_0^1 (df(x)/dx) g(x)dx = f(x) g(x) |^1_0 - \int^1_0 f(x) Dg(x) dx = \int^1_0 f(x) [(\delta(x-1)-\delta(x)) - D]g(x) dx
? Please be careful to tell us exactly what you are doing! You start by talking about a vector space "V with dimension less than or equal to 3" but then start integrating? A vector space, of any dimension, does not necessarily contain functions at all. "A vector space with dimension less than or equal to 3" is NOT the same as "polynomials of degree 3 or less". (In fact, the space of polynomials of degree 3 or less has dimension four, not three, as you make clear by giving a basis consisting of four functions.)
In any case, what D* is such that <Du, v>= <u, D*v> depends upon what D is! Do you mean that D is the derivative operator?
Exactly: D is the derivative operator and I'm trying to find D*, which is simply the adjoint operator. I apologize for writing it so messily. I'm a first year graduate student still working on my writing skills, so if you have any suggestions, either for finding D* or improving writing skills, it would be greatly appreciated.
Figured this out. Since every operator takes one some matrix representation, and we consider the orthonormal basis with respect to the differentiation operator, we can extend that basis to matrix form. But there's a theorem that states the matrix representation of D* is simply the transpose of the matrix represented by D. Therefore, I'm all set. Thanks for the suggestions!
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
