MHB Adjoint operator and orthogonal projection
mathzero
Hello,
I want to show $ T^{*}(Pr_{C}(y)) = Pr_{T^{*}(C)}(T^{*}y)$
where $T \in B(H)$ and $TT^{*}=I$ , $H$ is Hilbert space and $C$ is a closed convex non empty set.
but i don't know how to start, or what tricks needed to solve this type of problems.
also i want know how to construct $T$ to satisfying
$ Pr_{x + C}(y) = Pr_{C}(x + y)$ and $ Pr_{\lambda C}(\lambda y) = \lambda Pr_{C}(y)$
Thanks!
mathzero said:
Hello,
Since $TT^* = I$, then $\|T^*x\| = \|x\|$ for all $x\in H$. Indeed, given $x\in H$, $\|T^*x\|^2 = \langle T^*x, T^*x\rangle = \langle TT^*x, x\rangle = \langle x,x\rangle = \|x\|^2$. Show that
$$\inf_{c\in C} \|T^*c - T^*y\| = \inf_{c\in C} \|c - y\|$$
and deduce $T^*(\operatorname{Pr}_C(y))$ is a point of $T^*(C)$ closest to $T^*y$. Then the result follows.
How does $T$ relate to those equations?
Thank you!
i want apply this result $T^{*}(Pr_{C}(y)) = Pr_{T^{*}(C)}(T^{*}y)$, to
$Pr_{x + C}(y) = Pr_{C}(x + y)$ and $Pr_{\lambda C}(\lambda y) = \lambda Pr_{C}(y)$
by creating $T$ first and later deducing $T^{*}$ (i don't know if this is possible!),
i imagine maybe, just by letting $Ty = y - x$ then $T^{*}y= y + x$? this can be possible?
mathzero said:
Thank you!
In the case $\operatorname{Pr}_C(\lambda C) = \lambda \operatorname{Pr}_C(y)$, you can take $T(y) = \lambda y$, for all $y\in H$, which defines an element of $B(H)$ with $\|T\| = \lvert \lambda \rvert$. For the other equation, you suggest letting $Ty = y - x$, but this does not define a linear operator unless $x = 0$.
I posted this question on math-stackexchange but apparently I asked something stupid and I was downvoted. I still don't have an answer to my question so I hope someone in here can help me or at least explain me why I am asking something stupid. I started studying Complex Analysis and came upon the following theorem which is a direct consequence of the Cauchy-Goursat theorem: Let ##f:D\to\mathbb{C}## be an anlytic function over a simply connected region ##D##. If ##a## and ##z## are part of...
