Chemical/Paint Advice on light-duty heat tolerant adhesive
  • Thread starter Thread starter Grinkle
    Heat
Attaching items to RV cabinet surfaces without drilling holes can be effectively achieved using velcro tape, allowing for easy removal and replacement of attached items. However, the adhesive on standard velcro tape may struggle with heat and humidity, leading to peeling. To enhance adhesion, users are seeking recommendations for heat-resistant glues that can be applied to the back of the velcro tape, while still allowing for eventual removal. Permanent solutions like epoxy are generally avoided due to their irreversible nature. Alternatives such as double-sided tape designed for carpets have proven too strong, causing damage to cabinet surfaces upon removal. Overall, the discussion emphasizes the need for a balance between strong adhesion and the ability to remove attachments without damaging the cabinets.
Grinkle
TL;DR
Looking for an adhesive to use in an auto interior
I don't like to put holes in the cabinet surfaces in my RV. To attach things to the surface of a cabinet I recently used velcro tape,one side on the cabinet surface, the other side on the lightweight thing I want to attach. I like being able to remove the attached thing and replace it as convenient, hence the velcro tape approach.
The adhesive that comes with the velcro tape is not always robust vs heat / humidity, and it can peel away from the surface it is stuck to. Does anyone have recommendations on a heat-resistant glue I can try using on the backside of the velcro tape for heat-tolerant fixation? I'd like to use something that is ultimately removable with sufficient effort on my part to clean it off, so I am trying to stay away from permanent epoxy unless I can't find any alternative.
If I epoxy velcro tape to a cabinet surface, it won't ever really come off that surface, I don't think, but there may not be any good alternative if I don't want it peeling when the inside of my RV becomes an autoclave.
Have you tried to google for "heat resistant velcro"?
Likes Baluncore and Grinkle
And there you have it. Thanks, not too hard after all.
Likes russ_watters
I tried the double stick tape they use for carpets in my RV. It's too strong! When I pulled it off, it peeled away the fake wood veneer on the cabinets. You could use it to permanently stick Velcro to the wall, but for permanent mounts you might as well drill holes.
Hey folks! So I’m kinda losing my mind over my hedgie’s setup lately. No matter what I do, the enclosure keeps getting super humid and it’s starting to smell funky. I clean it, switch bedding, crack the window, the whole nine yards… but it still ends up damp and I’m worried it’s gonna mess with my little dude’s health. I’m starting to feel like I’m doing something wrong even though I’m trying so hard. Has anyone dealt with this before? Any tips, hacks, gear recs… literally anything would...
  • · Replies 42 ·
  • · Replies 49 ·
