Advice regarding sled experiment
rlosey
Hello. I would like to design an experiment where different sled designs are compared. Specifically, I would like to asses how sled design affects the amount of force required to pull a sled over 100 meters. Any suggestions you might have would be greatly appreciated.
What research have you done so far? What have you found out? What is your level of scientific knowledge?
I have the sleds built. The proposed load for each sled is 75 kg. I also have a relatively flat surface to test the sled on--a flat frozen lake bed. The idea is to test traditional Indigenous sled designs, which I am very familiar with. However, I have nearly no physics experience.
Likes PeroK and Dale
There are two aspects to the force required to move a sled across ice. There is a coefficient of static friction, which determines the initial force required to get the sled moving. Once the sled is moving, there is a coefficient of kinetic friction which determines the force required to keep the sled moving at constant speed. The kinetic friction will be lower than the static friction.
In summary, you'll need an initial higher force to get the sled moving and then a lower, sustained constant force to keep the slep moving at constant speed. The sustained force is probably the one you want. The distance is irrelevant. That simply determines for how long the force must be maintained.
There will be an optimum angle above the horizontal at which to pull the sled. This depends on the coefficient of friction. For a low coefficient of friction, the optimum angle will be only slightly above the horizontal. However, if the static friction is quite high, you may find it's easier to pull the sled slightly upwards initially until you get it sliding. This might be something that you've picked up naturally. In any case, there is an optimum angle which requires the minimum force to pull each sled.
This itself could be used as a test. The better the sled is at sliding, then lower the angle at which it feels natural to pull it.
The tricky part is, of course, to get any quantitative data from an experiment on the ice. Otherwise, you are relying on your senses to determine which is easer to pull. There's no obvious way to rig up equipment that would give you any output in terms of a force.
One approach to calculating the coefficient of kinetic friction would be to get the sled moving at some constant speed and then see how long it takes to slow down and stop. If there is no equipment, an experiment could be done with two people. You get both sleds moving at the same speed and then release them at the same time. Then measure how far they slide before stopping. For a direct comparison between two sleds, you don't need any data.
If you know the starting speed and the stopping time and/or distance, you can calculate the coefficient of friction from that.
Wouldn't a spring balance (fish scale) give a reasonable measurement of the force needed to pull the sled?
Likes PeroK
That was my thought as well. But, you also need to consider the pulling angle and the constancy of the sled speed, as @PeroK mentioned. You will need to come up with a mechanism to ensure the speed is constant and the same between tests. I'm envisioning that the rope is wrapped around a drum that turns at a fixed speed, or something like that. If the sled speed is not constant, the spring scale reading will bounce around.
FAQ: Advice regarding sled experiment
How do I ensure the safety of participants in a sled experiment?
Ensure participants wear appropriate safety gear, such as helmets and padding. Conduct the experiment on a controlled, obstacle-free course, and have medical personnel on standby. Additionally, perform a thorough risk assessment and establish clear communication protocols.
What equipment is essential for a sled experiment?
Essential equipment includes a reliable sled, safety gear (helmets, pads), measuring instruments (speedometer, accelerometer), and a well-maintained course. You may also need data recording devices and environmental sensors to monitor conditions like temperature and wind speed.
How can I accurately measure the speed and acceleration of the sled?
Use GPS devices or speedometers to measure speed. Accelerometers can provide data on acceleration. Ensure that these devices are calibrated correctly and securely attached to the sled to avoid data inaccuracies.
What variables should I consider in a sled experiment?
Consider variables such as the sled's weight, the slope of the course, surface conditions (snow type, ice, etc.), and environmental factors like temperature and wind. Also, account for the physical condition and skill level of the participants.
How do I analyze the data collected from a sled experiment?
Use statistical software to analyze the data, focusing on key metrics like speed, acceleration, and distance traveled. Compare these metrics under different conditions to draw conclusions. Visualize the data using graphs and charts to identify patterns and correlations.
