B Air Gun Sighted at a Falling Target Demonstration
When firing a bullet at a falling target released simultaneously, they will collide if air resistance is negligible. However, air resistance affects both the bullet and the target differently, complicating the trajectory of each. The bullet's path is typically parabolic without air resistance, while with it, the bullet slows down and follows a more complex trajectory. The target's descent is also influenced by air resistance, which may not match the bullet's trajectory, leading to variations in their collision point. For practical classroom demonstrations, the effects of air resistance are often small enough to be ignored, but they become significant in more complex scenarios.
mopit_011
So in class today, we were talking about how if you fire a bullet aimed at a falling target and release the target and the bullet at the exact same time, they will surely collide. I asked if air resistance (since it’s not a constant force) wouldn’t affect the collision and my teacher didn’t have a response. Could I have help please?
Likes hutchphd, vanhees71 and PeroK
Hi,
:welcome:
Good question !
Without air resistance the bullet trajectory is a parabola (the black line in the picture here ) .
That is what your exercises will want for your near future.
With air resistance the bullet slows down considerably and follows a (much) more complicated trajectory.
The target will also experience air resistance, but most likely not in the exact same way as the bullet (feather target? brick target?).
It would be somewhat coincidental if both drop equally far over the distance of the shot.
Likes Klystron, vanhees71 and hutchphd
If the drag force of the air has no vertical component (only affecting the horizontal velocity component) the target will still be intercepted although the juncture may change.
Typically the drag force is antiparallel to the velocity itself and so the result may be affected. Obviously for the classroom demo these effects are small enough to ignore (because most of the drag is in fact horizontal).
Your Prof probably didn't want to wander off into the weeds ! But you know intuitively that a very highly viscous fluid will ruin the result. Depending on your level of skill you could refine this question...like how much does air drag affect the result etc etc. Good question.
As already mentioned, air resistance will slow the bullet and the velocity of the falling object, but because the velocity profiles of each of those is different, it becomes a more complicated problem.
But for short-range monkey falling problems, the monkey does not do so well...
mopit_011 said:
I asked if air resistance (since it’s not a constant force) wouldn’t affect the collision ...
In general, it will. Imagine the target hangs on a parachute (not uncommon in war).
Thread 'Is 'Velocity of Transport' a Recognized Term in English Mechanics Literature?'
Here are two fragments from Banach's monograph in Mechanics I have never seen the term <<velocity of transport>> in English texts. Actually I have never seen this term being named somehow in English. This term has a name in Russian books. I looked through the original Banach's text in Polish and there is a Polish name for this term. It is a little bit surprising that the Polish name differs from the Russian one and also differs from this English translation. My question is: Is there...
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
