Automotive Air speed in car radiator -- Heat Exchange calculations
The discussion revolves around calculating the heat exchange area of a car radiator using the equation Q = U*A*LMTD. The user is attempting to determine the external convection coefficient, which requires the Reynolds number, dependent on air speed. They express concern that their initial calculation for air speed does not account for the fins, leading to potentially inaccurate results. Other participants suggest that experimental methods to determine the heat transfer coefficient U could be more effective, emphasizing the need for research into existing heat transfer correlations for air flow across finned tubes. The conversation highlights the complexities of accurately modeling forced convection in radiator systems.
r4m0n0
Hello, this is my first post. This question is related to my final thesis.
I'm calculating the heat exchange area of a radiator through heat exchange equations:
Q = U*A*LMTD
I have as data Q, and LMTD (this one through trivial calculations)
In order to calculate U, I need the coefficients for external and internal (both tubes and fins) convection.
Internal convection coefficient is quite easy to calculate.
My doubts come when trying to calculate the external convection coefficient. As you may know to calculate the coefficient you need the Reynolds number (amongst other things).
Reynolds depends on the fluid speed (in this case air speed) and in order to calculate it I thought of the following equation:
v=(V_dot_air)/(no.of tubes*area of tubes) --->
The thing is... this calculation doesn't take in account the fins of the radiator, thus not having an accurate value for velocity.
But if I took in account the area of the fins into the equation, the velocity of air would be very VERY slow.
Can anyone suggest a better way to calculate air speed through a car radiator?
Thanks in advance :)
(Image enclosed: a simplification of a car radiator)
It's forced convection not natural convection .
Mass flow and velocity of cooling air is primarily determined by the cooling fan and possibly by forward velocity of vehicle depending on ducting arrangement .
If you have data on Q and LMTD, then you have enough to calculate U experimentally. So why are you trying to calculate it from the flows?
Chet
@Nidum:
Yes, it is forced convection, I never said otherwise. I'm calculating the air velocity "from scratch" so in order to know how the ducting arrangement and the cooling fan type/size I must calculate before the air velocity.
@Chestermiller:
Calculate U experimentally? Can you give me more insight on that? I have no physical model, everything is theorical.
Oh. You didn't say that. OK, how do you know the coolant flow rate to get the heat transfer coefficient on the tube side?
There are definitely heat transfer correlations available for air flow across banks of finned tubes. But you need to do the research yourself to find them.
Chet
Here's a video by “driving 4 answers” who seems to me to be well versed on the details of Internal Combustion engines. The video does cover something that's a bit shrouded in 'conspiracy theory', and he touches on that, but of course for phys.org, I'm only interested in the actual science involved. He analyzes the claim of achieving 100 mpg with a 427 cubic inch V8 1970 Ford Galaxy in 1977. Only the fuel supply system was modified. I was surprised that he feels the claim could have been...
TL;DR Summary: Heard in the news about using sonar to locate the sub Hello : After the sinking of the ship near the Greek shores , carrying of alot of people , there was another accident that include 5 tourists and a submarine visiting the titanic , which went missing Some technical notes captured my attention, that there us few sonar devices are hearing sounds repeated every 30 seconds , but they are not able to locate the source Is it possible that the sound waves are reflecting from...
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
