I Airflow through an air extraction grill
To achieve uniform moisture removal from fabric in a plenum system, the airflow through the fabric is more critical than the grille's design between plenums. The resistance of the fabric determines how air flows; if the fabric is uniformly porous, it will dry evenly. If the fabric is smaller than the opening, airflow will be uneven, drying edges faster than the center. The grille's impact on airflow uniformity is minimal; the focus should be on the fabric's properties. Understanding airflow dynamics and resistance is essential for effective drying solutions.
Hedgehope
TL;DR Summary
Two spaces separated by an open grille, does reducing pressure in one space draw air through the grille from the other space in a uniform manner ? (volume, pressure & velocity)
Hello,
New member here, brainstorming some ideas for my 'invention'
I need to draw the high humidity air contained in plenum 1 into plenum 2 in a uniform manner to assist with evenly removing the moisture from a single layer of fabric, suspended parallel in plenum 1
My question is does placing a 'simple' (evenly spaced, consistent thickness) grille between the two plenums achieve this ? Or is there more to this than meets the eye ?
Welcome, @Hedgehope !
Air tends to follow the path of less resistance.
The effect of the grille on the uniformity with which the air will flow through the cloth is debatable and depends much on the geometry of the whole system.
The added grille makes no difference.
If the fabric covers the entire opening, and the air is drawn through the fabric, then the airflow through the fabric depends on the resistance to airflow of the fabric. If some portions of the fabric are more porous than other areas, the porous areas will flow more air and dry faster. If the fabric is evenly porous over the entire area, then it will dry evenly.
If the fabric is smaller than the opening, then the air will flow around the fabric and dry the edges faster than the middle.
There certainly is more to drying than meets the eye. You might find it interesting to read about drying large amounts of paper by searching paper machine dryer section. It's not directly applicable to your situation, but will give you some idea that there is more to drying than just setting a fan in front of something wet.
Likes DaveE, berkeman and Hedgehope
I agree with this, though my first reaction was to disagree due to the wording of the OP:
I'm not sure of the thought process here, but uniform flow through the grille isn't important, just uniform flow through the fabric. Perhaps you're envisioning something like flow straighteners on a wind tunnel, but resistance vs a plenum is what creates uniform flow for your type of situation. You can achieve uniform flow through the grille with a high pressure drop/low free area, but the fabric pressure drop is likely to be pretty high, so that won't have any impact since it will already be uniform coming through the fabric (assuming the fabric is uniform).
Thread 'Is there a white hole inside every black hole?'
This is what I am thinking. How much feasible is it? There is a white hole inside every black hole The white hole spits mass/energy out continuously The mass/energy that is spit out of a white hole drops back into it eventually. This is because of extreme space time curvature around the white hole Ironically this extreme space time curvature of the space around a white hole is caused by the huge mass/energy packed in the white hole Because of continuously spitting mass/energy which keeps...
Why do two separately floating objects in a liquid "attract" each other ?? What if gravity is an emergent property like surface tension ? What if they both are essentially trying to *minimize disorder at the interfaces — where non-aligned polarized particles are forced to mix with each other* What if gravity is an emergent property that is trying to optimize the entropy emerging out of spin aligned quantum bits
