Algebra Help for Bernoulli's Equation
To solve for v1 in the equation P1 + (1/2)ρv1^2 = P2 + (1/2)(v1r1^s/r2^2)^2, the key is to recognize that both sides contain v1 terms. By rearranging the equation, you can isolate the terms involving v1 and factor them out. This leads to a simplified expression where you can solve for v1 more easily. The discussion highlights the importance of correctly identifying and managing the powers of v1 on both sides of the equation. Ultimately, factoring out common elements will allow for a clearer path to finding v1.
NRasmus1
Solve for v1
I am attempting to solve this equation for v1, but I am getting stuck on some algebra. How do I solve for v1? I can't figure out how to do it without eliminating v1 altogether because I have a v1^2 on both sides of the equation.
No on the left you have v1^s and on the right you v1^2 so you still have v1 around to solve for.
I just caught that! I had intended v1^s on the left side to be v1^2
so you're going to get something like
(P1 - P2)
= (1/2v1^2 * r1^2 / r2^2 - 1/2 * p * v1^2)
right?
so then factor out 1/2 and v1^2 then solve for v1
I feel like a moron. Thank you very much.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
