MHB Algebra/Physics problem - kinematics
  • Thread starter Thread starter mathkid3
    Kinematics
To determine the runway length required for a light plane to reach a takeoff speed of 33 m/s with a constant acceleration of 3.8 m/s², the kinematic equations are applied. The initial velocity is assumed to be 0, and the time to reach the final velocity is calculated using the equation V = V0 + at, resulting in approximately 8.68 seconds. Using the equation for distance, x = x0 + V0t + 1/2at², the total runway length is computed to be 143.30 meters. This calculation confirms that a minimum runway length of 143.30 meters is necessary for the plane to achieve its required speed for takeoff. Understanding these kinematic equations is essential for solving similar physics problems.
mathkid3
A light plane must reach a speed of 33 m/s for takeoff. How long must the runway be if the plane has a constant acceleration of 3.8 m/s2 ?so, I am new to kinomatic equations. We are using the 4 Basic ones.
need to see this one worked out if I may.Thanks
Mathematics news on Phys.org
Re: Algebra/Physics problem
What is the target variable? That is, what is it for which you're trying to solve?
distance?
What is it that you are given? And how may we relate these values?
Another way of saying what MarkFL said is this: can you write down a relevant, correct equation involving the target variable of distance?
I think the OP meant the kinematic equations, 4 basic ones meaning:
1) x=x0+V0t+1/2at2
2) V=V0+at
3) a=constant
4) V2=V02+2a(x-x0)
If this is the case, the answer is a matter of determining starting values.
We can assume that the plane starts off at point 0 on the runway meaning that x0=0. we can also assume that the plane's initial velocity is 0, V0=0 (before moving). now we are given the acceleration, a=3.8m/s2, and final velocity, V=33m/s. From this we can find how long it will take the plane to reach the final velocity, using equation 2:
33m/s=0+(3.8m/s2)t
t=(33/3.8)s
Now that we have a value for t, we can use equation 1 to find the total runway length, x, required to reach takeoff speed:
x=0+0(t)+1/2at2
=(1/2)(3.8m/s2)((33/3.8)s)2
=143.30m
therefore the minimum amount of runway needed to reach the plane's necessary takeoff speed is 143.30 meters.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
