MHB Algebraic Fraction: How to Solve and Simplify?
  • Thread starter Thread starter mathlearn
    Fraction
To solve the algebraic fraction equation $$\frac{3 }{ 2(x+1)} + \frac{1}{x+1} = \frac{5}{6}$$, the common denominator is determined to be 6(x + 1). By adjusting the second term's numerator to match the first term's denominator, the equation simplifies to $$\frac{5}{2(x+1)} = \frac{5}{6}$$. Solving this leads to the solution x = 2. Verification of the solution can be done by substituting x back into the original equation. The final answer is confirmed as correct.
mathlearn
Hi,
Can you help me on this problem. I'm not sure on how to solve this and please be kind enough to explain your steps little bitMany Thanks:)
Mathematics news on Phys.org
mathlearn said:
Hi,
Hint: What is the common denominator for these fractions?
-Dan
not sure might be (x+1) or 2,1?? :)
The common denominator will contain 3 terms: (x + 1), 2(x + 1), and 6. So it must have one factor of (x + 1) and a factor of 6. (The 6 = 2 x 3, so it contains the 2 automatically.) So you are looking for 6 (x + 1), right? Can you take it from there?
-Dan
Just multiply the numerator and denominator of second term of LHS by 2 to equate it's denominator to the first term of LHS.
$$\frac{3}{2(x+1)} + \frac{1}{x+1} = \frac{5}{6}$$
$$\frac{3}{2(x+1)} + \frac{{\color{red}{2}} \cdot 1}{{\color{red}{2}} \cdot (x+1)} = \frac{5}{6}$$
$$x=2$$
Verify it by substituting the value of $x$ to be 2 in the LHS.
Many Thanks (Smile)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
