High School Algebraic Operations on Energy-Momentum Relationships
The discussion centers on confusion regarding the energy-momentum relationship in basic algebra, specifically the misapplication of square roots in calculations. The participant acknowledges a potential decline in their calculation skills due to age. Corrections are made, indicating that square roots should not be present after squaring terms. A simplified equation is presented, leading to a clearer understanding of the relationship. The conversation concludes with a realization that the expression simplifies effectively, reinforcing the importance of careful algebraic manipulation.
alan123hk
This is just basic algebra for the energy-momentum relationship, but the calculations confuse me. May I ask what is wrong with my concept or calculation causing the following problem.
Maybe it's because I'm getting older, my ability to think and calculate has declined...
Second line counting from the bottom - the square root should not be there since you raised it to the second power in the third line from the bottom.
weirdoguy said:
Third line counting from the bottom - the square root should not be there since you raised it to the second power.
My goodness!
got it, thanks.
Simpler is
$$E^2 - p^2 c^2 = \gamma^2m^2c^4(1 - \frac{v^2}{c^2})$$And the result follows immediately as the expression in brackets equals ##\frac 1 {\gamma^2}##
Topic about reference frames, center of rotation, postion of origin etc Comoving ref. frame is frame that is attached to moving object, does that mean, in that frame translation and rotation of object is zero, because origin and axes(x,y,z) are fixed to object? Is it same if you place origin of frame at object center of mass or at object tail? What type of comoving frame exist? What is lab frame? If we talk about center of rotation do we always need to specified from what frame we observe?
  • · Replies 30 ·
  • · Replies 23 ·
  • · Replies 17 ·
  • · Replies 138 ·
  • · Replies 28 ·
