MHB Algorithm: maximize sum of increasing functions
The discussion centers on finding an algorithm to maximize the sum of increasing functions under a constraint on their inputs. The user, David, seeks to determine values \( n_i \) for multiple increasing functions such that the sum of these values does not exceed a specified limit \( N \), typically around 500. For two functions, exhaustive search is feasible, but the complexity increases with more functions. A suggested solution is the Downhill Simplex method (Nelder-Mead), which David plans to incorporate into a larger optimization framework. The conversation highlights the challenge of integrating heuristic solutions for subproblems within this optimization context.
Pereskia
Hi!
(Not sure which forum to pick for this question. This looked like the best one. I apologies if it is not)
I have a number of functions (say m functions) with integer domain. All functions are increasing. (Increasing in the sense not decreasing, $f(n+1) \ge f(n)$.) I want an algorithm to find $n_i$ for $1 \le i \le m$ such that $\sum_i^m n_i \le N$ that maximizes $\sum_i^m f(n_i)$.
$m$ is usually small (2 or 3) but can be larger as well and $m$ = 2 can be solved reasonably fast by exhaustive search, $m\ge3$ takes more time. Typically $N\approx 500$.
Is there any known algorithm?
Regards
David
Mathematics news on Phys.org
Pereskia said:
Hi!
Regards
David
Hi Pereskia! Welcome to MHB! (Wave)
How do the different functions tie in?
I only see the single $f$, so we seem to have $m$ numbers instead of $m$ functions.
Hi!
Sorry, I want to maximize $\sum_{i=1}^m f_i(n_i)$. I lost the index $i$.
Regards
David
I like Serena said:
Then I think you are looking for the Downhill Simplex method (Nelder-Mead), which is also called the Amoeba method.
Thank you. I will add this method to my tool box.
I will however need the optimum in this case. It will be one part of a larger optimization algorithm. I don't know how the other parts will work with heuristic solutions to the subproblems.
Regards
David
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
